Who needs Iron X?
Discussion in 'Car Detailing Product Discussion' started by cptzippy, Apr 4, 2011.
  1. Legacy99
    Legacy99 Wax on..Wax off
  2. togwt
    Detailer's clay and decontamination are two different processes. The abrasives 'shear' the surface contaminates, the sheared particles are then encapsulated by the clay (i.e. the top of the metallic particle leaving the rest embedded in the paint, which acts as a conduit for moisture to the various paint layers, allowing it to continue generating corrosion damage
  3. grease
    grease Birth of a Detailer
    I was using a paint decontamination kit from Valugard.
  4. Emile
    Emile Welcome to Detailing
    I could be wrong about the Sonax, I only tried it on a small area and didn't give it much dwell time but I saw no color change at all. I don't like using wheel cleaner on vehicle paint anyways, so I just rinsed it off and never tried it again. The powder-coating on wheels is much much stronger than vehicle paint so you can't just assume that if something is safe for your wheels, then it's safe for your paint.
    Legacy, as far as I've been able to tell, IronX doesn't do a darn thing to the wax, and its performance as a pre-wash is very similar to 1Z Anti-Insekt.
  5. Emile
    Haha, I'm gonna pass. Sonax WHEEL Cleaner is very clear about its purpose.
  6. kyoshiro
    kyoshiro DB Forum Supporter
    Sonax Wheel Cleaner Full Effect
    You saw nothing!
  7. d964
    d964 Two Bucket System Washer
  8. GTPAUL
    GTPAUL DB Forum Supporter
    I beg to differ about it not removing wax. I just bought a white Pontiac Torrent and used IronX about 500ml for the entire vehicle. Vehicle was waxed prior and water sat on paint after Iron X so it clearly removed any hint of protection.
  9. cptzippy
    cptzippy Jedi Nuba
    Wasn't going to but got some of the spray and also got some of the Full Effect wheel cleaner. I'll have to wait till it gets here to really start my spring clean up I guess but it'll be interesting to see how they work.
  10. tonipieleanu
    tonipieleanu Any Rag Vehicle Washer
    Sonax FE works on paint, but my feeling is that it's very mild.
    Here's how it worked for me.
    Before:
    Sonax FE applied (I use the trade version which over here is a clear liquid)
    After 2 minutes of working time:
    Little red dots start to appear:
    Rinsed with Kwazar Venus and dried. No adverse effects noticed under the Brinkmann:
    Use on your own caution!
  11. kdude
    kdude Jedi Nuba
    I guess the pics don't lie.. :)
