I had a Toyota Truck to detail today interior and exterior no paint correction. Wash,claybar,applied CG Ez cream glaze by Da with 5.5" black finish pad on number 3, did whole vehicle, removed with microfiber several of them. Wet Diamond was applied with yellow foam pad, a dot size of dime and worked lighty on surface, so easy to lay down, went around whole truck, top and then bottom. While that was sitting on surface I then went to remove a product used on glass Glass Scrub, used on chrome rims,and wow have to say took all deposit out, then after that put a layer of 845 to seal the rims. I then removed glass scrub from all other chrome. I went to remove Wet Diamond off of surface of truck, I have to say what a difference,,the paint is Metalic Silver, very impressed with the look, very reflective look. I really like this product, not counting out Powerlock which has its place, but choose this combo..also glass scrub a decent product used on glass and chrome..worked by hand lightly mist area to apply it to..will post pics tomm..do i use photobucket for this? thanks.:applause2:
You mean "gold" pad. The yellow pad is a coarse cutting pad and the gold is for applying waxes and sealants.
