1. MrPolished&Waxed
    SuperBee364 Im still wondering what exactly you do? are you just squeezing out solution on to the panel, then wiping, then rinsing?
    I just need a more detailed explanation as far as putting the wash media on the paint? You didnt that say you do that?
    thanks
  2. SuperBee364
    SuperBee364 Birth of a Detailer
    It depends on the wash media, but if I'm using a (grout) spone, I squeeze the solution out as I'm *gently* wiping it across the paint. If it's not a sponge, I use the *fully* saturated media on the paint in small sections. No matter what media, I rinse after each very small area.
  3. MrPolished&Waxed
    is this for more of a post paint correction wash method?
    are you using the home depot grout sponges?
  4. SuperBee364
    Yeah, for post paint correction washings on cars that are too dirty to wash touchless or ONR. I have been using Home Depot grout sponges (thanks to Spoiled Man's recommendation on "the other" board), but lately I've been using tufted MF mitts. I *really* like the tufted MF mitts. Very seldom do I even do a traditional wash, though. Only if the car is *really* dirty. Normally, I'll do a touchless wash (HP rinse, layer of foam, HP rinse) followed by a leaf blower to dry. If the car is still a bit dirty, I'll follow up the touchless wash with an ONR, or I'll use a boar's hair brush after the layer of foam.
    Boar's hair brushes are another really great wash media. They flick the stuff off the paint, then push it in front of the bristles (kinda like a broom on your garage floor), rather than being pressed into the paint and dragged along it like a sponge/wash mitt. The problem with BHB's is they are *so* gentle that they aren't able to clean as effectively as a sponge/mitt. If you have an LSP that readily releases surface contaminants, BHB"s can be very effective wash media.
  5. Denzil
    What are these tufted MF mitts that you speak of Supe?
  6. Reflect
    I'd imagine it can't be all that bad for the suds to be going into the rinse bucket. I'd figure some of the suds have to be encapsulating the dirt and grime and bringing it with it into the bucket. The bad side is that it probably keeps some of the grime floating at the top.
  7. MrPolished&Waxed
    does anyone know the difference in feel from the home depot GS to the Zymol Sponge and the Uber Sponge? thanks
    how about a wash review of any of the 3 sponges post paint correction? thanks
  8. Denzil
    I would be happy to do the review but unfortunately I only have one of those sponges, LoL.
  9. advs1
    advs1 DB Forum Supporter
    hehehe i use the no bucket wash system. i break out the PW and foam cannon, spary with water, foam, wait rinse. unless the car is really bad. most of the time they are only repeat washes and i have already waxed or sealed the car. the foam cannon really makes it so i dont need a bucket. i can get a regular sized sedan done in 10 mins.
  10. SuperBee364
    I'll take a pic of one and post it, Denzil. You'll know exactly what I mean once you see a pic, they're just hard to describe.
  11. Mindflux
    Mindflux Welcome to Detailing
    Supe,
    I woke up this morning to a startling revelation. How can you be such a fan of a foamer and not a fan of suds (which is in essence foam)?
    Just a little something to ponder over?
  12. SuperBee364
    I just blast the foam off with my pressure washer. No media is used.
    When I do use media is when I hate suds. Running soapy water = flushed off particles = nothing stuck under wash media to abrade paint.
    1. HP rinse
    2. Foam cannon
    3. HP rinse
    Usually done at this point, but if media is used:
    4. *suds free* media wash
    5.HP rinse
  13. cshorey
    cshorey Any Rag Vehicle Washer
    When using Buckets I don't generate any suds in the buckets and wash pretty close to the method that SuperBee described. I guess my goal was lubricity, and didn't really realize I wasn't generating suds.
    I an currently experimenting with using a foam gun while washing as well (direct foam into point where wash medium meets paint), which is kinda funny cause i still use the buckets in the same fashion with this. So now basically I am adding foam to my no suds wash.
    I guess I am still learning a wash technique for myself.
    chris
