Spray bottels (paul dalton ) uses?
Discussion in 'Car Detailing Product Discussion' started by trhland, Jun 3, 2010.
  1. pektel
    pektel DB Forum Supporter
    My favorite sprayers right now, other than the CG 16 oz bottle/sprayer, is the Zep sprayer. I've tried the .96 home depot ones, no good for me. The Zep one has held up to Tardis, without clening the spray head after use, for over 3 months now. A little pricey at 3.97 each (also available at Home Depot), but it's worth it to me.
  2. Ad me to the least of cheapskates :gidiup:
  3. P1et
    Even my Viton chemically resistant sprayers aren't immune to Wheel Brightner.
  4. supercharged
    foaming sprayers from ADS work well with Megs WB. I've been using them for a while and never had a problem...
  5. Mindflux
    Mindflux Welcome to Detailing
    My viton sprayers aren't immune to Meg's APC+ :/ I had 3 sprayheads replaced by spraymaster because of APC+ (old formula)
  6. metsfan
    metsfan Birth of a Detailer
    The zep spray bottles at hd are much better than the 97 cent ones . zep ones are just as good imo as the gray ones that cost more .
  7. trhland
    trhland Nuba Guru
    ive been useing us plastic spray bottles but these throw aways .. therenot heavyduty .. but ok for the price though...
  8. supercharged
    Thomas, they are all made with a theory - it breaks, so you buy a new one, so our technicians can have a job...
    In other words if it will continue on working for you, you will simply stop buying...
  9. bjungx007
    bjungx007 Birth of a Detailer
    im telling you, you guys need to check out sams club! its 6 bucks for a 8 pack and 2 are foaming heads. Ive been using them over 6 months and only 1 foaming head went out.
  10. trhland
    trhland Nuba Guru
    makes sense... maybe ill just stick with the cheap ones.. im just s sucker for fancy marketing what can i say :thumb:
  11. agpatel
    agpatel OD On Detailing
    idk what you guys are using other than WB but I have never had a sprayer go bad one me. I use the cheap ones from US Plastic (gray spray head ones, chem resistant) on string dilutions of many APCs, citrus cleaners, heavy degrease, and all my chem.
    Dont worry trhland, i am a sucker for fancy packaging also...gotta look good on the shelf :lol: One reason I have a few of those SV mixing bottles with some QDs in them. Not only do they look nice but the mist sprayer is perfect for QDs.
  12. Emile
    Emile Welcome to Detailing
    Agreed, never had a sprayer go bad on me. But I also flush the sprayer out with water after each use (when using APC, Degreaser, Megs WB, etc.).
    In fact, for WB, I usually first spray soap/water through it (usually from my wheels bucket) and then run water through it.
  13. trhland
    trhland Nuba Guru
    i brake bottles all the time but its usaully because i drop them ..
  14. agpatel
    Dont flush mine anymore , i give my sprayers no mercy. muahahah!
  15. Paul Dalton aka Miracle
    Paul Dalton aka Miracle DB Pro Supporter
  16. 911Fanatic
    Just had a look. Paul, you're a bad influence!
  17. SuperBee364
    SuperBee364 Birth of a Detailer
    I buy the generic Meguiar's maroon bottle quick detailer just for the spray bottles. I use the QD up fast as a clay lube, then put my good stuff in the bottle. This bottle has one of the nicest, most even spray patterns you'll see in a spray bottle. Totally even coverage, with no gaps, and no too-much spots. It also doesn't atomize the liquid into a too-fine spray that disappears in the breeze, or when you take a breath.
    I haven't bought this in a while, though. Don't even know if the maroon bottle Meg's detailer is even sold anymore.
  18. detailersdomain
    talking with the mfg and getting pricing and samples next week, stay tuned...
  19. scoTampa
    scoTampa Virgin Detailer
    Update: I picked up some of the Zep sprayers from Home Depot. They are $4 each and they are much nicer than the $1 ones. They spray more per pull and the spring is more powerfully loaded. Also the spray adjustments seem to have a broader range.
    Home Depot also has a sprayer that is resistant and inert for use with chemicals. It's $6 and it looks pretty nice (as nice as a bottle can look). Just something to check out next time you are in the HD
  20. trhland
    trhland Nuba Guru
    phil you rule!!!!!!!!!! try tio get 22 ounce bottles and 32 ounce.. sonetimes its nice to have a smaller spray bottle . its nice having both .
