RR Drophead Metal
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by billyblooshoes, Aug 22, 2011.
  1. billyblooshoes
    so i have a customer that was sent to me through a friend/customer. the owners have two rolls royces: a phantom and a phantom drophead. the drophead is the model with the brushed aluminum hood and accents. i have been using optimum metal polish for a long time with great results, but i want to double check with those of you that have experience with this car. should i just polish out the aluminum hood by hand? or would using a DA with say a black pad and the metal polish be a safe method? additionally, is there another product i should look into picking up that someone with experience with these cars recommends?
    (i think i got the models right. i know my cars, but im not well verses in RR)
  2. Wheelz25
    Wheelz25 Jedi Nuba
    honestly I'm not sure if a metal polish would be the right thing to use on this as it might effect the look of the brushed aluminum.
    If i remember correctly Bob has experience with these and even uses his own special technique....you might be able to ask nicely for him to divulge that info.
  3. premshine09
    premshine09 Jedi Nuba
    Thats a nice referral! Have fun with those two!
  4. billyblooshoes
    yeah i know dave and bob have done a few. thank you.
  5. billyblooshoes
    yes quite good. while my friend is finishing up putting a 7000 sq/ft addition on their estate, ill be attending to the RR's. we both win lol.
  6. P1et
    Does it need to be polished? I have polished brushed aluminium before and it's difficult to get "even" results. I did it with a DA and a black pad. It's often very easy to see the difference between one area you polished and another area. I'd be careful, and if it doesn't need to be polished, just wash and it dry it nicely.
  7. billyblooshoes
    its not horribly faded, but it could use some polishing. the car is a 2010 i think and hasnt had very much attention paid to it. i couldnt help but notice the armor all and turtle wax in the cabinets.
  8. agpatel
    agpatel OD On Detailing
    I would go with a pure paint cleaner...but would hold off till you can get some solid advice from a trusted person who has actually done one. I know Swissvax had a line made for RR which is pretty much the opaque line for use on the hood bits.
  9. LostHighway
    LostHighway Jedi Nuba
    Unless you can get some info direct from RR I'd hold off until you talk to someone that has successfully worked on that finish. I suspect the aluminum either has a clear anodized finish or a clear coat. Straight aluminum and most aluminum alloys form an oxide layer fairly rapidly. Depending on the surface treatment even mild abrasives could land you in a world of trouble.
  10. billyblooshoes
    yeah im not doing anything to the car until i get some things cleared up by notable detailers who've worked on them.
    i just need to know what to do with that metal, how to do it safely, and if i need to have anything expressed to me that i dont have already.
