Rotary. Which one would you get?
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by supercharged, Apr 14, 2009.
  1. supercharged
    are you guys also on 110 volts in Canada? I have getting special adapters, which are made in third world countries and break often...
  2. Nica
    Same voltage super :thumb:
    Adaptors? :shead: what adaptors?
  3. kei169
    kei169 Wax on..Wax off
    I am in the same boat as urs super, i want to get a rotary, and i am in a dilema of getting which one.
    AFter reading these posts, i still couldn't decide which to get..sign
  4. supercharged
    same voltage? never mind, then.
  5. togwt
    Rotary Polishers- a high-speed polishing machine (Porter-Cable 7428, a Makita, DeWalt, Metabo, Hitachi, etc, which are all fine high-speed rotary machines) that have a direct-drive with selectable speed control that maintains a constant speed under varying loads conditions.
    •Porter-Cable 7428 - reliable , 10-amp motor, variable speed 0- 3,000 RPM, 9 Lbs weight
    •Metabo – ergonomically sound , variable speed 700 – 2200 RPM, 10-amp motor, 6 Lbs weight
    •Makita 9227C –a reliable workhorse, ‘soft start’ and variable speed 600-3000 RPM
    •DeWalt DW849– a reliable machine, 8 Lbs weight, 1000 – 3000 RPM,8-amp motor
