Rightlook Wash Mat
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by 911Fanatic, Dec 12, 2009.
  1. 911Fanatic
    For $100, I picked up a pump that I use to pump it into my laundry sink. Works like a charm. Saves turning the parking lot into a rink! The neighbours like that.
  2. Deep Gloss Auto Salon
    Very Nice Ken....
  3. agpatel
    agpatel OD On Detailing
    Random thought but I know for pool covers you can get one of those small pumps you put on the cover to remove the water that collects on top, I assume this would work pretty well for a matte like this and they are pretty cheap. Find them at any pool supply place.
  4. kustomizingkid
    kustomizingkid Nuba Guru
    I bet you could build one for much much cheaper....
  5. detailersdomain
    its was 22 degrees out last weekend not fun.
  6. agpatel
    Pool cover, or tarp, and a wood frame, 5" high with a side that is able to be moved to roll a car over? haha
  7. Dust2Glory
    Dust2Glory Nuba Guru
    Nica
    To be honest with you, the pressure on the berms is for a split second, to drive over it takes no time at all, and then to drive off... i think it would take years for any noticeable wear or tear for that matter... if it did tear, they make repair kits for the vinyl and I imagine the foam would be replaceable although I don't remember if the ends open up or not.
  8. willjco
    willjco DB Forum Supporter
    i would make a PVC frame because it is light and you can remove one side to get a car in then lay a tarp over top to contain the water
  9. brk4euros
    brk4euros DB Pro Supporter
    I use mine all the time! Only complaint is that the surface can be damn slippery!
  10. Bunky
    Bunky Guest
    Do you do a traditional wash? If so, how much water do you use?:100post:
  11. 911Fanatic
    I concur. Wiped out on mine last week. X Games quality wipeout! LOL
