Removing Cement
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Dust2Glory, Jan 1, 2010.
  1. Dust2Glory
    Dust2Glory Nuba Guru
    Ok guys for a update.....Back-Set is off the CHAIN!!! This stuff works miracles!!! It literally turned the cement back into mush!!! And it took all of about 2-3 minutes! Did it all come off... no, there was a little blob in the area that I was working on, but seriously this stuff is amazing.
    And about the price, for cement removal you can charge WHATEVER you want. On this car the body shop was going to charge over $6000 to repaint and replace all the lower plastic pieces. I am charging $1500 to remove all the cement, wash, clay, minor polishing and seal the vehicle.
  2. bimmer nation
    bimmer nation Birth of a Detailer
    Where do u get back set?? And it doesn't harm the paint at all???
  3. Dust2Glory
    Right now it seems top of the line, is the best place to get it. And no it doesn't harm paint at all! It's active ingredient is found in sugar cane syrup or something of the sorts.. No acids at all
  4. Nica
    So what happened to Viniger? Does it work just as good as this Back Set?
  5. togwt
    Vinegar is only good for 'fresh' cement, once its hardened (set) BackSet reverses the hardening process
  6. Nica
    Ah okay I see, thanks for the feed back togwt, learned something new :thumb:
  7. togwt
    Amazing what sugar can do !!!
