Problem with Menzerna products. Need resolution.
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by JoeyV, Nov 6, 2010.
  1. JoeyV
    JoeyV Welcome to Detailing
    Yup, had this issue on other brands (Honda and Hyundai) but then again, I had no issue on the RX-8. It was also sticking with the PC, just not in as big of clumps.
    THIS is something I should try. Since water dries up quite fast, the oil is a good idea. And if you say it doesn't affect the product, then that's great!
  2. detail addiction
    detail addiction DB Pro Supporter
    In mine and a few body shops I help outs experience we have found the PG does not have the "cutting" power of a product such as M 105. I too had an issue with my PG but it was replaced by my distributor. As far as adding an oil to the pad to help it last a little longer, I would recommend Gloss It Pad prime however, only use a small amount as too much will diminish the effectiveness of the cutting compounds of the product. PM me if you need some Pad Prime.
