pressure washer recommendations???
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by supercharged, Apr 1, 2010.
  1. togwt
    You need to keep the flow rate of the water below 3 gallons per minute to allow the resin to thoroughly clean the water
  2. Deep Gloss Auto Salon
    2 gpm
  3. metsfan
    metsfan Birth of a Detailer
    I am in the market for a new pw for around 200 dollars .Has anyone used the snap on pw ? Price isnt bad and snap on is a good name .
  4. Rennes
    Rennes Jedi Nuba
    I have a snap-on one that I got from Costco. I hate it ...
    Pros:
    It's quiet
    Cons:
    everything ...
    When using it, the pressure will just stop. You have to trigger a couple of time and then the pressure is back on. Then off again.
    If I remember correctly, they are made by Karsher.
  5. metsfan
    I ended up buying the snap on 2000psi to try out .I got home and used it then brought it right back . That thing does suck . I didnt have the trigger problem that you had but i highly doubt that it even put out 500psi . It wasnt even taking the soap off my car at 10ft away . I used to have a 1400 psi from hd that i could write my name in the ground with at full pressure . I think im used to using a higher gpm too because the snap on was just a light mist and barely got anything wet .
    I went to home depot to look at what they had since i used to like the old one i had but there new ones look crappy .They all have like a clear crimped on hose and is one piece . im looking for somthing that is upgradable . I did like the ridgid ones and they have a ton of attachments for it at hd but its a bit too big for me .
    What options do i have in pw's as far as being able to upgrade stuff ?
  6. racersky
    racersky Jedi Nuba
    I was thinking about trying their 1600psi one from HD. I like the fact that it has a quick disconnect at the one end of the gun so I could connect the foam lance to it. I might give that a try and if I don't like it I will just return it.
  7. froboy272
    froboy272 Obsessive Detailer
