Porsche Boxster - Paint Correction & Opti-Coat Pro by Mr. Sparkle Detailing - Long Island, NY
Discussion in 'Professional Detailer's Studio' started by Mr. Sparkle, Mar 20, 2016.
  1. Mr. Sparkle
    Mr. Sparkle DB Pro Supporter
    Got the call a few months ago to correct a Porsche Boxster which proved to be quite a battle so figured I would share some photos.
    The owner had recently picked up the car and knew it was in poor condition to say the least. Swirls, deep random scratches and overall dull finish. We agreed to a multi step paint correction with long lasting protection from Opti-Coat Pro (5yr warranty on all exterior paint).
    Opti-Coat Pro is a Silicon Carbide coating (SiC) not Silicon Dioxide like many others on the market (SiO2). This means low maintenance over the life of the coating (no silica spray needed) and no drop in gloss through oxidation over time.
    Did the usual wash / decon / clay routine, taped off the trim and got down to business.
    Inspection under LED lighting.
    I found this paint to be surprisingly hard. To get it right, I had no choice but to wet sand a bit in certain areas.
    3000 grit machine dampsand
    5000 grit machine dampsand
    Shine Supply Flat Top + Flex PE Rotary + Lake Country Purple Wool
    Shine Supply Classic Cut + Griots DA (Boss & GG6) + Megs MF Cutting pads
    Opti-Coat Primer Polish + Griots DA + LC White
    Before you make an omlette, you must break a few eggs.
    50/50 Wetsand on the left / Finishing Polish remaining on the right
    Did some final prep with Optimum Paint Prep and applied Opti-Coat Pro to all exterior paint, trim and wheel face
    Indoor glory shots
    Outdoor glory shots in direct sun
    From the home of the swirl free finish here in West Babylon, NY
    Mr. Sparkle Detailing.com
  2. Sizzle Chest
    Sizzle Chest New Member
    Very nice work! Came out fantastic!
