PO85RD vs 106FA
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by yiyiyi204, Feb 8, 2009.
  1. Denzil
    I'm curious but what would be acceptable for a one-step polish with the Menzerna line? Can you use Power Finish as a one-stepper or would 106FA be more fitting? I'm being pretty general so I guess it could be situational.
  2. eyezack87
    eyezack87 Guest
    Can't wait for my Power Finish to come in along with the green pads from PAC :applause:
  3. PhoTuGo
    PhoTuGo Jedi Nuba
    Would WMF w/ black = jeweling, actually i don't really get jeweling what is it? more gloss?
  4. billyblooshoes
    thanks man. i love that thing.
  5. billyblooshoes
    i would think 106FA would be fitting as a one-stepper as far as menz goes, although i have never tried the power finish.
  6. bgray
    bgray Birth of a Detailer
    Does Power Finish really work as good as SIP, or very close?? I dont wan to scrafice any correction, but if i could save a step...then by all means i will..
  7. 911Fanatic
    Power Finish is as close to a one step as you can get as far as the Menz line is concerned. It does cut very close to SIP and definitely finishes down good enough to go to your LSP if you use a Green or White pad. I'll be posting an Infiniti I recently did that was pretty bad and all I used was Power Finish and an assortment of pads, from the Menz compounding pad down to LC Green CCS. 106FA doesn't have near the correcting ability of Power Finish.
  8. 911Fanatic
    Sorry, but what is WMF? You're right. Jewelling is just getting more gloss out of the paint using a pad and polish that have very little to no mechanical action, meaning very little cut.
  9. PhoTuGo
    PhoTuGo Jedi Nuba
    WMF = CG Wet Mirror Finish
  10. 911Fanatic
    I've been meaning to try it but haven't as of yet. Maybe someone else could chime in on this.
  11. TexasTB
    TexasTB Obsessive Detailer
    I agree. I tried them side by side last night on my van (SIP and PF), and PF finished down very nicely and ready for LSP. IMO, SIP has a little more bite, not much, but PF leaves a better shine. Both will have a place in my detailing arsenal.
  12. bgray
    Hmm...Powerfinish then finish with 85rd would save me alot fo steps for a car that doesnt nessesarly need all the cutting power of IP or SIP..
  13. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    It sure will, I just don't get how some do not follow up powerfinish with a finishing polish and pad.
  14. Denzil
    So I guess you can really only one-step with 106FA/PO87MC/PO85RD then?
  15. Asphalt Rocket
    If that is all it needs, just like a clean up type polishing if it has been well kept. Otherwise I always follow up with a finishing polish.
  16. Denzil
    Ah ok, thanks. I was thinking of situations in which clients are too cheap for a two-step or multi-step and just want a one-step. :shead:
  17. Asphalt Rocket
    If the vehicle needs a two or three step, that is what they are getting, if they do not want that then I won't do it. If you explain the purpose or do a little show and tell of the 2 or 3 step I have found 99% of the time they are sold.
  18. Denzil
    Ah, I see... I haven't run into the cheap-client situation... yet. :giggle:
  19. Asphalt Rocket
    Neither have I, you are slow on your posts tonight-lol
  20. Denzil
    Yeah, I'm actually working on school projects while I'm online, hehe. Sorry to keep you waiting! :p:
