Paint Thickness Gauge (PTG)
Discussion in 'Car Detailing Product Discussion' started by togwt, Feb 14, 2009.
  1. togwt
  2. richy
    So does this one do plastic surfaces? How much?
  3. Misha
    Misha Nuba Guru
    ^^doesnt look like it. looks it does same as highline meter HF II or I
  4. Reflect
    It looks like it does from the description. It says the F probe can pick up plastics.
    * The F probes measure the thickness of non-magnetic materials (xxxxx Paint, plastic, porcelain enamel, copper, zinc, aluminium, chrome etc. ) on magnetic materials (xxxxx Iron, nickle etc. ). Often used to measure the thickness of galvanizing layer, lacquer layer, porcelain enamel layer, phosphide layer, copper tile, aluminium tile, some alloy tile, paper etc.
    * The N probes measure the thickness of non-magnetic coatings on non-magnetic metals. It is used on anodizing, varnish, paint, enamel, plastic coatings, powder, etc. Applied to aluminum, brass, non-magnetic stainless steel, etc.
    * Automatic substrate recognition.
  5. Reflect
    But now that I think about it, It may measure only the thickness of the plastic. Yea I read it wrong.
  6. Misha
    Misha Nuba Guru
    when those coatings applied to aluminum, bras and stainless steel.
    those descriptions are confusing
    The F probes measure the thickness of non-magnetic materials on magnetic materials.
    The N probes measure the thickness of non-magnetic coatings on non-magnetic metals. (aluminum and SS are not magnetic)
