Optimum Opti Coating
Discussion in 'Sale, Trades, or Bargains' started by Obsessive Detail, Nov 9, 2009.
  1. Obsessive Detail
    Actually, the retail on this is $100 and with your member discount here it is only $90.00!
  2. Twisted007
    Twisted007 Banned
    Now on the pomponazzi coating only say cause was mentioned. once mixed has to be used in a matter of a few hours or more depending on how much you mix is that the same for opti coat?
    also can you get bigger sizes?
    Now with some other coatings you can use on rubber an plastic can you do same with opti?
  3. Obsessive Detail
    You don't have to mix it at all, it is ready to go in the syringe that it comes in. I get a few vehicles out of each syringe, so it dosn't go bad right away. You just want to keep it in a temperature controlled area.
    The only size that it comes in now is 40cc. which actually goes a very long way.
    Yes, you can use this on glass,metals, and plastics as well. I have it on my wheels, plastic trim, glass,and paint. It is pretty cool seeing the plastic trim beading like the paint does.
  4. Twisted007
    Twisted007 Banned
    what about rubber trim?
    now i use a small mf to apply the other coatings you this foam pad would be better?
  5. Obsessive Detail
    I've put it on rubber trim a few times and didn' have any problems. I've had the best luck so far with using a foam applicator to apply it, but I know of a lot of people that prefer using a microfiber towel. I think it is really personal preference.
  6. Twisted007
    Twisted007 Banned
    The reason i ask so much is there really is limited info. out there about it an when i use it on higher end auto's i want to know the a-z about it lol. i have had great results with the coatings i have used but cause out of country hard to get an pricey cause i have to buy alot to make sure i have until i get more.
    I think this will be better as easier to get a hold of plus more cost affective in the long run.
    any vids on how you apply an the start to finish en results?
  7. RNickolas
    RNickolas Obsessive Detailer
    This sounds perfect for my wife's expedition (just set it and forget it!). is there a specific temperature range that you have to apply it in?
  8. Jedidiah
    Jedidiah Guest
    or my dads truck that is kept outside un garaged.
    Nice sales pitch Justin. it is on my list of things to buy once it is warm :0)
  9. atomicfan
    atomicfan Any Rag Vehicle Washer
    iam interested in the coating.
    Can you ship it to Austria?
  10. Obsessive Detail
    I completely understand all of your questions.
    I haven't seen any videos on how to apply it. The application is so very similar to putting on Opti Seal, you basically wipe it on and most of it just dissappears right away, the heavier spots will leave a slight haze, you just gently buff those areas with a microfiber towel.
  11. Obsessive Detail
    I wouldn't apply it under 50 degrees.
  12. Obsessive Detail
    Yes, I pretty much ship everywhere.
  13. atomicfan
    How much would it cost?
  14. Obsessive Detail
    Let me get you a shipping quote and I will send you a pm.
  15. RNickolas
    looks like ill order some in the spring!
  16. Twisted007
    Twisted007 Banned
    oh ok same as the pomponazzi an liquid armor coatings those are the two i use the most. i think this is worth a shot i get alot of my opt direct from kev let me see if he going to carry if not i get from you thanks .
    an how long does it last if not opened ?
    an if opened how long?
  17. Obsessive Detail
    I've been told that it will last for over a year if unopened. If opened it is still going to last for several months if you keep it sealed. I put mine in a baggy when I'm done with it.
  18. Twisted007
    Twisted007 Banned
    thanks great help an info. i'll pm ya as soon as talk to kevin.
  19. atomicfan
    could this also be used on boats?
  20. Jedidiah
    Jedidiah Guest
    OMG i bet on a boat it would be great. if it really is that magical.
