Opti-Lens Release Date
Discussion in 'Car Detailing Product Discussion' started by SoCal Garage, Jan 27, 2013.
  1. SoCal Garage
    What's latest on the release date of Opti-Lens? Thank you.
  2. vtec92civic
    vtec92civic Nuba Guru
    Awesome. How does this apply like a wax or a aerosol spray?
    What is the said durability?
  3. Gale Force
    Gale Force Obsessive Detailer
    I did a VW Jetta headlights at the beginning of January. I just coated them with Opti-Seal until this is available. When I contacted Optimum about Opti-lens, they were expecting a release date of mid/end January and lifetime durability. I'm not sure how they came up with "lifetime" but if I can safely promise a minimum 2 years to a customer I'll be happy.
  4. Chris@Optimum
    We're just waiting on the labels.
    Opti Coat Pro has an available "lifetime" warranty, that may be what you're thinking of.
    Opti Lens will have a consumer version and a pro version. They will both be permanent (ie there until you polish it off abrasively).
  5. GDAL
    GDAL Super Moderator
    I'm really excited about this product. I haven't touched my headlights because I have been waiting for this product. I promise to post a review thread for this one!!
  6. 911Fanatic
    How will this differ from Opti Coat Chris?
  7. Kaban
    Kaban Welcome to Detailing
    Very cool.
  8. Gale Force
    Yes, thanks for the correction.
  9. Chris@Optimum
    Opti Coat doesn't contain high levels of UV protection, because all it has to do is prevent the loss of UV protection that's found in paint.
    Polycarbonate has no internal UV protection and is fully dependent on the protective coating applied when new. The original coating will last a couple of years, but with exposure to UV, cleaners, etc it fades in protection until completely gone.
    Opti Lens is a hybrid coating combining silicon carbide and acrylic to address the issues we see with plastics. Opti Coat would certainly prevent oxidation and form a hydrophobic surface, but the addition of acrylic for light transmission and flexibility along with increased UV inhibitors make a substrate specific coating that outperforms any other compound used on plastics.
  10. JsDtell
    JsDtell Any Rag Vehicle Washer
    is there going to be a difference in durability w the opti lens vs the opti lens pro or are the warranties the same as the OC and OCPro
  11. JoeyV
    JoeyV Welcome to Detailing
    I think this is the first product I'm actually excited about and am waiting for...not just from Optimum, all products included Can't wait for this to be available in Canada.
  12. chefwong
    chefwong Birth of a Detailer
    Looking forward to this.
    I've always had film on my headlights. When they start going iffy, I just replace the film.....
    The plastic under is always good and no *need* to polish and remove the UV coating..
  13. SoCal Garage
    I started covering all our vehicles headlights in clear film protection in 2009, but we have an older daily driver about to sold/traded-in that I used Plexus on and the lens went to hell, crazing and just terrible looking around the perimeter of the lens which is a separate, but molded piece of the lens. Going to give Opti-Lens a try on these after taking them out of the car and sanding/prepping them. I will say that clear film protection saves you an immense amount of grieve on many fronts.
  14. RaskyR1
    RaskyR1 Jedi Nuba
    Chris, can you comment on whether this product contains enough UV inhibitors to act as a replacement UV coating when doing headlight restorations? The kind where you completely sand off the OEM coating?
  15. Chris@Optimum
    Yes it does. That is the major difference between Opti Coat and Opti Lens. We also added acrylic for increased flexibility since headlights are continually bouncing back and forth regarding temps.
  16. P1et
    What happens when you put this on your lenses and some of it gets on the paint?
  17. 911Fanatic
    Oh, so you're one of those guys!
  18. Kilo6_one
    lol...
  19. GDAL
    Any updates Chris? I'm dying to use this product!!
  20. Chris@Optimum
    It won't harm paint. It actually works on paint too although it may haze a little easier thar Opti Coat on paint. It manageable though.
    Their telling me this month for sure, but I don't know what the holdup is at this point. Heck I could have crayoned out new labels by now.
