Need help identifying/correcting paint defect (pics)
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by e92, Feb 28, 2012.
  1. e92
    e92 Virgin Detailer
    Hello!
    Been doing a lot of reading and thanks to this great site I've applied much of what I've learned with great success. However, it seems I have now hit a road block...
    Quick background... Car is a jet black 3series that has spent it's first four years in San Fran (mostly sitting outside...hardly driven). I purchased the car last year and so far have done the following:
    Clayed extensively (clay bar kept turning into sand paper throughout the entire process)
    Compound & Polished with rotary using some random chemicals I found at the dealership I used to work at (not sure how aggressive they were)
    At first glance the car looked perfect however under the right lighting conditions there seems to be some particles/contaminates embedded in the clear. Now when I clayed the car the paint was left smooth to the touch so I'm not sure if this is a clay issue or something that requires a wool pad with a really aggressive compound.
    Looking forward to your responses, and thank you for your time!
  2. drew935
    drew935 Auto Salon Works
    I would hit it up with M105 and an LC tang pad with the rotary. You need to know the info of the compound and polish to correct it properly.
  3.
