What is the working time of the microfiber system compound when using their microfiber cutting pad? Anyone have experience? Edit: I mean 300, obviously.
Good working time and finishes down nicely, not like M105, but if you need more cut add a dot of 105. D300 is a pleasure to work with, softer paints may require a finishing polish to finish down nicely.
I have always used Menz. PF 2500 but I am also curious about the D300 and its application. Would this be something I would work with right after clay barring the car? Do I need to add a final polish after I use the D300? Any input will be appreciated!
I used the Megs microfiber system yesterday and was pleasantly surprised. I worked the D300 quite a bit and didn't have to reapply product often.
With normal to soft paint and average to light damage the d300 on a mf pad alone will be a one and done process, harder paint or increase in imperfections will need a bit more low end umph, add one or two drops of m105 and work like normal. IPA, then wax or seal, with MPL and a good towell the paint will look as good as its ever going to get.
