Meg's MF Cutting Pad not "sticking" on Backing Plate
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by JordanL, Jan 12, 2014.
  1. JordanL
    JordanL Virgin Detailer
    Hey everyone, I just picked up some 5" Meg's MF cutting pads from Phil. I just put them on my GG 6" that is paired with the uber 5" backing plate to see how they fit and to me they felt a little loose compared to the foam pads that I've used on there. I turned on the machine and it put it on speed 5 and after a few seconds the pad started to wobble, like it was going to fling off so I stopped it and the pad had shifted of center from where I placed it. Have you experienced this before? I don't really know what to do at this moment. Thanks - Jordan
  2. Woob
    Woob Jedi Nuba
    Is the backing foam connected firmly to the MF portion? Message Meguiar's they will make it right.
  3. JordanL
    Yes, it fees like it's connected properly. I did happen to phone meguiars and they blamed my backing plate for the pads not sticking, but the other foam pads i've used like the uber's work fine.
  4. RZJZA80
    RZJZA80 Two Bucket System Washer
    The Megs MF pads don't even stick very well to the Megs backing plate. I switched to the LC backing plate and it sticks just fine, go figure.
  5. EbbeJ
    EbbeJ Jedi Nuba
    Or even better - get the Mirka backing plates and pad savers.
  6. Mdintx
    Mdintx New Member
    I haven't had problems with the Cutting Pads but I had big time problems with the Finishing Pads. One flew off the polisher when I was cleaning it. I had a set of 3" Finishing Pads. One of those came apart while using it and the other was already separated.
