Loving this P21S Wheel Gel
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Showcasedetail, Dec 31, 2009.
  1. gian995
    gian995 Virgin Detailer
    I use the Meguiar's Wheel Brightner (i wear thick rubber gloves when using WB) diluted as per instructions on the spray bottle once a year after the winter to get all the grime and built up brake dust from the back of the wheel. I think it may be 4:1 or 8:1. Once they are sparkiling clean, I apply Klasse AIO and SG to seal them. Throughout the summer I will wipe the wheels down with a quick detailer to extend the Klasse protection.
  2. Brian N
    Brian N Jedi Nuba
    Do you mean basic? Or are you saying everything below 10? Because as I am sure you know 7.0-10.0 would be slightly basic as it seems the P21s gel is.
    If it wasn't a typing error then my mistake, just thought it could use come clarification what the German manufacturers mean. Below 10 is a big range, I could understand 7.0-10.0 but if it ever got into the 2 or below range that would be kinda scray hehe. :thumb:
    Oh yeah almost forgot, Emilie you should edit you post on the second page to GI wheel gel to pH balanced not neutral. :)
  3. Emile
    Emile Welcome to Detailing
    I meant between 7 and 10. I will update the posts when I get home. I also need to test Diablo and GI Wheel Gel with my pH test strips tonight.
  4. pektel
    pektel DB Forum Supporter
    With regards to wheel gel cleaners; How much do you guys use? I probably only use 4-8 oz per set of wheels. I've heard of others using quite a bit more, but to me that seems like overkill.
  5. agpatel
    agpatel OD On Detailing
    I use about 10oz for 4 wheels. Yeah it may be overkill but oh well, its not that expensive really...only really need to use that much if it go long times between cleaning...normal cleaning i use the leftover car soap to clean the wheels. I know some use 24 oz and some use less...
  6. tin
    tin Any Rag Vehicle Washer
    I figured out how much I use. A 22oz bottle of Zymol gell lasted me 6 details giving me an average of 3.66oz per 4 wheels. One of those cars was an Escalde with particularly bad 24" chrome wheels so a good amount more was used on that car. I would say on average an ounce per wheel is appropriate, being such an effective cleaner, any more is just wasted, IMHO. I agitate with a Zymol boars hair brush with the gel to get them minty. Behind the spokes gets hit with a good degreaser and a long brush.
