I need help..
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by er1k, Apr 21, 2008.
  1. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Go to detailierdoamin and scroll down, click on the flex tool emblem and it goes right to all the polishers.
  2. er1k
    er1k Obsessive Detailer
    I know this is not the DA and it is a rotary. But could someone explain to me the difference between a rotary and the DA..
    Flex Tool L 3403 VRG (Rotary)
  3. Nica
    Well the rotary spins in a circular motion, creating more heat but will do paint correction faster. The DA, oscillates. It still produces some heat but not as much as the rotary and will take a bit longer to do paint corection. The oscillation motion makes it harder to burn through a clear coat.
    But like it was mentioned earlier, if you’re not careful even with a DA you can burn through clear coat.
  4. togwt
    Pros- the Porter Cable random orbital buffer is manufactured as a sanding machine, but can be adapted as a very safe polishing machine, as it lacks the power to burn paint. It is very easy to use and is ideal for very minor paint correction and the application of car care products
    Cons- it lacks the power to produce the friction-heat required to breakdown the diminishing abrasives in polishes designed for hard clear coats and / or paint correction / renovation, although it could be used for this purpose utilizing 4-inch foam pads to increase surface friction / heat it is very time consuming
    Alternative random orbital buffers - Flex XC 3401 VRG, Bosch Gex 150 Turbo, Festool Rotex - RO125, Makita BO6040 Polisher (alternate between circular or dual-action modes)
  5. er1k
    Alright well now I'm stuck haha. What do you all recommend?
  6. Blackwater
    Blackwater Virgin Detailer
    If I had it to do over again, I would have skipped the time I spent using a Porter cable and
    gone straight to the 3403 rotary. It is does what I need it to do in half the time the DA took
    And the results are better.
  7. haper
    haper Birth of a Detailer
    I'm a newbie to buffers and skipped right to the Flex (see my 'first experiences' in the Flex section of the forums). The Flex is better in all ways to the PC and just as safe to use so it really comes down to money.
    To afford the Flex over the PC I skipped the glaze and wax for my first detail. I'll get those once I save up some more cash. FWIW, here's what I ordered for my 2001 330ci:
    10x All Purpose Towel - 16" x 16"
    Clay Bar & Clay Lube Combo
    Jet Seal 109 - 16 oz
    PO106ff Ceramic Clear Coat Polish - 16 oz
    SIP PO83 - 32 oz
    Flex Tool XC 3401 VR (Orbital)
    1x CCS Pad 6.5 inch Blue (Final Finish)
    3x CCS Pad 6.5 inch White (Light Polishing)
    3x CCS Pad 6.5 inch Orange (Polishing/Light Duty Compounding)
    1x CCS European Hand Applicator Pad (RED)​
    here is what i did:
    CCS Orange - Light Cutting Pads
    use w/ menzerna SIP
    prep pad by soaking in water (distilled if possible), ring out, place in terry cloth towel, spin w/ machine (in empty bucket to previde splattering)
    nickel size of polish for 18 x 18 inch section
    squirt like ketchup around the outer edge of pad
    blot / rub polish from pad onto surface b4 turning on buffer to avoid splattering
    start Flex at level 1 or 2 and move quickly to spread polish evenly
    then up it to 5 or 6 moving 1 inch per second over lapping 50%
    just b4 poilish breaks down drop to 3 and do one last pass to minimize hazeing
    3 – 5 mins until broken down
    as polish thins out lighten up the pressure and increase movement
    stop once the polish breaks down (begins to dust)
    remove w/ microfiber towel
    the finish will not be perfect – it is normal as the SIP creates / leaves the smaller ​
    imperfections
    might need to a spritz of 1:1 solution Isopropyl alcohol (IPA) / distilled water to help remove​
    CCS White - Polishing Foam Pads
    use w/ menzerna 106FF (nano)
    follow same process as SIP
    all scratches, spider webs should be gone​
    CCS Blue - Finessing Foam Pad
    used to apply JetSeal​
  8. Usjdmtuner
    Usjdmtuner Wax on..Wax off
    PC is very good for beginners who has no confidence but still have to be careful and pay close attention to what you are working on..
    Ive learned that using smaller pads like 5.5" for Pc works best because you can focus on small areas..
    You can pick any of these polishers and get good result, its just the matter of preference. I would start on PC or flex 3401 orbital and detail few cars and then step up to Rotary like makita, dewalt, hitachi or flex 3403... Its really up to you.
  9. 67c2
    67c2 Virgin Detailer
    Hello,
    When I was in Lo Angeles in summer, about a month before the Pebblebeach Concourse
    will be held, those detailing shops with good reputations were busy. And I was there to
    gather come materials to show their work on the Japanese car magazine and what I saw
    there was kinda unbelievable.
    What I saw was that a recently restored Ferrari 275GTB4 was brought in, which was the
    car that being invited for the concourse. The first thing those pros did on the car was to
    spray the light coat of the black lacquer paint on the beautiful red body panels. Then after
    dried, they started rubbing the panels with the soft women's napkin like pads with using
    the Blue Poly metal polish to level the paint surface.
    The owner of the shop who is so well known in the Los Angeles area told me that the work
    was done to make the whole painted surface as the true mirror like flat finish. And then
    told me that most of the high grade metal polish works really well for as the polish for
    almost anything on the car body. It contains a bit of a anmonia which cuts the oily dirt
    and works just fine. It is basically for metal and so works just fine for the hard clear coats
    used for today's cars.
    So try the high end metal polish which is recommended for jewelry and so on. Do not use
    the one fraom Amway because soon as you squeeze out the thing from the bottle , you
    can feel the rough sand like strong abrasives which is just fine for the stainless steel but
    others.
    I used it to lighten the swirl marks on the black VW and it worked just fine. But remember,
    delicacy is always required.
