Has anyone found a clay/ lube combination that can achieve no marring?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by ampbmw, Feb 3, 2012.
  1. HeavyD
    HeavyD DB Forum Supporter
    Im not sure about his clay lube. But a guy like Ken,Id guess vaseline.:dbanana:
  2. Socal Brian
    KY for better lubricity! lol
  3. joep
    joep Welcome to Detailing
    Your applying a sealant not polishing why not wash the car use a good paint cleanser and call it a day...
    Sent from my iPhone using Tapatalk
  4. P1et
    Personally, metallic paint and you should be OK. However, non-metallic... different story.
  5. Stokdgs
    Stokdgs Detail Master
    I also vote for DODO Juice Born Slippy as a Clay Lube.
    Tried Meguiars Quick Detailer, Clay Magic's Lube, Chemical Guys Clay Luber, and ONR, and Born Slippy is the slickest and leaves nothing behind to have to remove. A little 250ml bottle makes 2.5 Litres. Doesnt hurt Detailed Image, Blackfire, Zaino, or Clay Magic Claybars at all.
    This is all I will be using from now on.
    Dan F.
  6. HeavyD
    Anyone try Optimums Instant Detailer? Dilutable 1-4 which would make it economical. Ive used it as a wipedown but not a clay lube??
  7. sikedsyko
    sikedsyko DB Forum Supporter
    This is my current favorite clay method. I buy ONR for the sole purpose of mixing it up as a quick detail spray and clay lube.
  8. 911Fanatic
    Clay Magic Bodyshine #49 is by far the best clay lube I've used. Its super slick and stays wet longer than anything else I've tried. Sonus Glyde is another very good one. I find that a dedicated clay lube, for the most part, are slicker than QDs.
  9. 911Fanatic
    KY over Vaseline every time!!
  10. GloomyX
    GloomyX Birth of a Detailer
    Where can I find Exclusive Yellow Clay?
  11. bryansbestwax
    It's exlcusive, you have to be on the guest list to get some that's what makes it exclusive.:p: Message 911fanatic. I am also the BS 49 user, and I find another QD from a Canadian company also pretty decent. A true QD wins every time in my books.
