Good Spray Wax
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by ps3king, Apr 13, 2010.
  1. ps3king
    ps3king Jedi Nuba
    Hi Guys,
    When you have clients who just want the basic wash and wax package instead of using one of your good nuba's ist here a good spray wax you can put on the car that is not only fast but effective?
    Applying a carnauba takes quite a bit of time compared to spray and wipe. So are there any spray and wipe waxes that give some amount of beading?
    thanks,
    -Waseem
  2. Strytnyne
    Strytnyne DB Forum Supporter
    duragloss aquawax =]
  3. dankfanatic
    dankfanatic Guest
    opt car wax gets my vote
  4. pektel
    pektel DB Forum Supporter
    Either of the above are great choices.
  5. Erik Mejia
    Erik Mejia Obsessive Detailer
    Optimum Car Wax or Opti-Seal. are both great. Opti-Seal is Wipe on Walk Away.
  6. sal329
    sal329 Nuba Guru
    Opt car wax, or use an easy on off paste like wet obsession
  7. ps3king
    ps3king Jedi Nuba
    whats the difference between Opti Seal and Optimum Car wax? Opti-seal appears to be close to double the price for half the quantity....
  8. Dsoto87
    Dsoto87 Jedi Nuba
    Ultima paint gaurd plus and optiseal are two very good wipe on walk away products that are great for situations that you mentioned.
    As for spray waxes AW and OCW are good. AW is a bit more user friendly in my opinion. That doesnt mean OCW is hard to use but i get streak every once and a while when working in the sun. I never get streaks with AW. Another great spray wax that isnt talked about much is Megs Ultimate Quik Wax. Works great in the sun also.
    If you want a bit more protection than those you should look into the Trigger line by jeffs werkstatt. Acrylic Jett Trigger is awesome stuff.
    EDIT: I just read your above post. Optiseal offers more and longer lasting protection than any of those spray waxes. It also has a different form of application. You simply wipe it on as thinly as possible. Thats it, it will flash off itself. Hence the acronym WOWA instead of WOWO
  9. mrgolfrider
    Opti-seal is a sealant, Optimum Spray wax is just that, a spray wax with about 2-3 weeks duribility.
  10. kc1337
    kc1337 Obsessive Detailer
    Werkstat Carnauba Jett
  11. slanguage
    optimum car wax, duragloss aquawax.
    Werkstat acrylic jett trigger is a spray on, buff off product, but a sealant instead of a wax. would last longer than the two I mentioned before.
  12. zachc
    zachc Two Bucket System Washer
    CG Blitz works too, very similar to Werkstat AJT.
  13. supercharged
    Pinnacle Crystal Mist.
  14. billyblooshoes
    Werkstat acrylic jett trigger is exactly what you're looking for. Like roger said, its a spray on buff off product with great looks and good durability. You can't beat it.
  15. sal329
    sal329 Nuba Guru
    I want to try the Werkstat products
  16. 911Fanatic
    What kind of durability are you looking for Waseem? The Werkstat Acrylic Jett Trigger will give you a few months with one coat, 6 months with two. If yo are going to go this route, make sure that you let your client know they are only getting a decorative finish that won't last long. Nothing will peeve off a client more than paying for a wash and wax only to have the LSP gone in 6 weeks. There are a few sealants, Colli 845, Duragloss 105, Blackfire, that offer great protection and are dead easy to use.
  17. 911Fanatic
    Then buy them already. What do you want, a sale?
  18. JoeyZ
    JoeyZ Obsessive Detailer
    Einzett Glanz Detail Spray
  19. corrswitch
    corrswitch Jedi Nuba
    I use optimum car wax. Easy to use, looks great. Cheap and fast. Smells great.
    Only thing is if you use too much it streaks. If it is humid, it tends to streak.
    I'll be trying Aquawax, hopefully this summer, I still have half a gallon of Optimum to use up.
    Opti-seal, also very easy to use. Still need to finish evaluating it. I did an entire car and hardly used much of the bottle. Very economical.
  20. cleanfiend
    cleanfiend Jedi Nuba
    did i just hear that autowerkes exclusive is having a sale on werkstat products? Great idea! you are the best hahaha :drinking2:
