Hello, I wanted to see a power comparison between the Flex and the PC and never found a table, so I made one and I want to share it with you: To run the Flex @6000 OPM (the maximum in the PC), you have to select the position "3.5" and with the Flex you have an extra, around 300 rpm. Best regards from Spain. :headbang:
Maesal. Thanks for the post regarding the differences between the two. Thats a pretty big difference!!! At speed 6 on the flex there are 3600 more OPMs than the PC. Pretty cool.
Thanks so much maesal that is some excellent information. Good info for folks debating purchasing a Flex as well since they can make a comparison on some concrete numbers.
Great Info. Thanks! Might I ask about your table, and how you made the measurements... I'm intrigued!
I just found the info in the net and I placed all the data in a table just to compare. You're welcome.
DOH! I thought you physically took measurements on some sort of mechanical table... not just put the info into a table... I'm not so smart sometimes...
Anybody know if there really any difference in the Speed Settings between the PC and UDM? (Ultimate Detailing Machine)
