FinishKare recommend?
Discussion in 'Car Detailing Product Discussion' started by ahwil_lim, Sep 30, 2009.
  1. ahwil_lim
    ahwil_lim Wax on..Wax off
    Hi guys,
    planning to get 1 galon of Fk425, many good review abt this. How about FK other lines? I cant find many info abt fk products.
    any1 using FK? pls recommend must a have items from FK
    thanks
  2. kaiten408
    kaiten408 Jedi Nuba
    2180 is a top notch sealant. Very easy to apply and remove. Probably my favorite sealant as of now.
    The glass cleaner is very nice, dilutable. Pink Wax is easy on/off and cheap. And 108 top kote is awesome.
  3. dsms
    dsms DB Forum Supporter
    the pH neutral shampoo is very nice as well. Supposedly has degreasing properties as well
  4. GoCubsGo
    GoCubsGo Any Rag Vehicle Washer
    I've used FK1000P on my wheels and it is soooo much easier to work with than Wheel Wax. I also plan on using 1000P as my winter sealant (topped with Pink Wax) after reading a lot of great reviews on it.
  5. kustomizingkid
    kustomizingkid Nuba Guru
    I've wanted to get some fk1000 but the really long curing time turns me off...
  6. froboy272
    froboy272 Obsessive Detailer
    i got a gallon of 425 and a tub of 1000p.
    the tub is huge and if your like me and only plan to use it on wheels. the cure time isn't that bad at all.
  7. ahwil_lim
    does it take how long for cure on paint surface?
  8. ahwil_lim
    Fk1000p is paste wax?
  9. Gemini13
    Gemini13 Obsessive Detailer
    30 minutes IIRC. I used it on monday on my moms Lincoln. Looks amazing on metallic.
  10. ahwil_lim
    so, we only need 30minutes for second layer? its fast dude ...
  11. getcha
    getcha Jedi Nuba
    2180 topped with 2685(or even 1000P) look awesome.
    218 with with 2685 is deep with a warm wet look.
  12. ahwil_lim
    what is different 218 & 2180? 1000p & 2685?
    thanks
  13. getcha
    getcha Jedi Nuba
    218 and 2180 difference is that 218 has less cleaners than 2180 and the look is warmer wet look where 2180 has a good cleaners and has a bright crisp wet look.
    2685 is a carnauba polymer blend wax with probably 4 months durability, super wet looking on reds and blacks and super easy to apply and remove. 300 hand glaze looks awesome under this too.
    1000P is a synthetic paste sealant with awesome durability and a clear crisp shine. Can sometimes be a pain to remove if you didn't apply it correctly.
    All of these look better after 24 hours, 1000P gets a sharp solid look to it.
    And all of their stuff is awesome prepped with #215 their AIO
    Where are you getting your stuff from?
  14. ahwil_lim
    Im not carrying any FK products for the time being. planning to purchase from Michael, will get 10%off if DB member.
    So, survey which FK must a have. Will take order together.
    thks for ur info anyway.
  15. uzj100
    uzj100 Jedi Nuba
    IMHO, 425, 108 and 1000P are "must haves". Pink Wax could easily fall in to that category as well.
    HTH
  16. kaiten408
    kaiten408 Jedi Nuba
    You have that backwards, 218 has more cleaners than 2180. Think of 2180 more of pure sealant, and 218 as a prep for it.
  17. getcha
    getcha Jedi Nuba
    218 has very light cleaners, similar to what you would find in another light sealant nothing super heavy like 1z Glanz. 2180 does have more cleaning than 218 and that why its used as a base for other things but just like any other product it depends on your application method. Give both products a good working in on an equal surface, you will be surprised. I was :thumb:
  18. kaiten408
    kaiten408 Jedi Nuba
    Dude, I'm looking at the FK1 website and it states that 218's cleaning ability is a 6/10 and 2180's is 3/10.
    It ranks 2180 higher in protection, durability, gloss and depth.
    Finish Kare FK1 Consumer Detailing Products
  19. getcha
    getcha Jedi Nuba
    Do you have any anecdotal experience with them? Or are you really just going off of that?
  20. kaiten408
    kaiten408 Jedi Nuba
    I've used 2180 before and really liked it. It was very easy to apply and lasted for a solid 3 months before I stripped it off.
    Given my experience with 2180, i'm going to go with my gut (and Finish Kare) and say that 218 has more cleaners in it. Hence the word "conditioner" in the name of 218
