dsms detail - Mini Cooper, Big Correction
Discussion in 'Professional Detailer's Studio' started by dsms, Apr 13, 2010.
  1. dsms
    dsms DB Forum Supporter
    Rotary'd the whole car and mirrors with the exception of a few areas where I couldnt use 2 hands.
    Go with the makita, I love my little flex and the metatbo is nice but for a solid unit the makita is perfect.
    You should never use a torque wrench to remove lugs, you can break them easily that way even if that have a switch for removing. I did used a torque wrench to tighten the lugs after :thumb:
  2. vtec92civic
    vtec92civic Nuba Guru
    To answer your question as i noticed it was overlooked i'm sure it was on accident . . . .
    A member on the forum sells extensions. PM me as i think i still have his screen name. The pad/backing combo is . . . . . Uber 3 in. backing plate with a Uber Orange 4 in. pad
    from Phil over at Detailers Domain
    that is a winning combo for a ton of stuff.
  3. Deep Gloss Auto Salon
    Great work as always (supa doopa fresh status):afro:
  4. trhland
    trhland Nuba Guru
    great work dave!!!! thanks for sharing ......
  5. Rennes
    Rennes Jedi Nuba
    ah, I re-read what i wrote, probably that bad french to english transalation in me that went wrong ;)
    I meant you can you use bar(breaker)/then torq to put them back in. Using the breaker bar will give you much more leverage :)
    sorry about that,
    marc
  6. Emile
    Emile Welcome to Detailing
    Very nice work.
    The inside spokes of the wheels are like pockets for brake dust accumulation, must have been tough to remove.
  7. P1et
    That red looks very wet, nice work!
  8. ps3king
    ps3king Jedi Nuba
    nice work as always man. ur details are super cool!
  9. kc1337
    kc1337 Obsessive Detailer
    Do you find the rotary harder to use with that long extension?
  10. dsms
    Not really, I think it works better with larger pads to be honest, I prefer using tiny pads without it but in tight spots the extension is nice. And it came with my metabo, I did not buy it separately.
    You are correct, partially, lol. The BP is DD and works great, solid and low profile. The pad is however 3" and from Griots Garage... a 4" pad is too big for certain areas so I use a 3" :thumb:
  11. racersky
    racersky Jedi Nuba
    love the outcome david
  12. dsms
    Owner was pleased as well, thank you:mounty:
