dsms detail - Beefy Correction on Hammered LS460
Discussion in 'Professional Detailer's Studio' started by dsms, Sep 11, 2010.
  1. bimmer nation
    bimmer nation Birth of a Detailer
    crazy good work dave
    is that the griot 3" DA?
  2. Rennes
    Rennes Jedi Nuba
    BTW, Dave, what kind of wool pad are you using in this detail?
    foam or regular one?
    Cheers,
  3. mutmanns
    mutmanns DB Forum Supporter
    that is the griot 6" with a smaller backing plate
  4. cnut
    cnut Guest
    Turnaround is an understatement! Great work indeed!!
  5. supercharged
    amazing work, David! Wetsanding seems to be like a lot of work, but ehn again it is very well worth it...
  6. XFS
    XFS Guest
    fantastic job man i really like it!!! :worship2:
    where did you find megs sand foam discs? i use 3m trizact at the moment and i really want to test the megs!
    is pleasant to wet-sand a Japanese paint but if you deal with BMW paint and wet-sand it ,is a nightmare until you get rid of the sand marks! hehe
  7. gav'spurplez
    gav'spurplez Virgin Detailer
    that door shot is brutal !!!
    awesome job, how many hours / days ?
  8. Carn
    Carn Welcome to Detailing
    Fantastic turnaround Dave :thumb:
    Had we not seen all the before and 50/50 shots one could easily be mistaken for thinking this is actually a brand new car!
    How many hours did you spend on this one btw?
  9. Misha
    Misha Nuba Guru
    this turned out great as usual, where did you get 3" meguairs wetsanding disks? 6" are not that comfortable to use and dont want to cut down 6" paper
  10. dsms
    dsms DB Forum Supporter
    Tell your friend I'm sorry, I probably severely cut down his weekly free time if thats true. And yes this was a 3-4 step correction, not a 2 step.
    Absolutely not. I own the Megs G110 v2, the Griots DA and a PC XP. By far the tighter orbits on the Griots makes for much better correction. If you think about it, with a shorter stroke machine your less likely to get deep pigtails when sanding because the rotation is not coming around from a further starting point, making the orbit itself tighter and IMO smoother, hence why the Griots is such a capable machine.
    Great memory Joe, may just have to do that one of these days.
    Lexus paint overall is great to work with the only problem is getting it to finish out clean after heavy compounding, with BMW black getting it to finish down on any stage can be a nightmare!
    Trizact and Megs are extremely similar, I honestly do not think there is a difference in performance.
    I honestly lost count David... I may have broken double digits on time :giggle:
    AG
  11. pektel
    pektel DB Forum Supporter
    Nice work. That black lexus paint is SOFT.
  12. Handz
    Handz Obsessive Detailer
    For the final finish down are you using 85rd on Green pad?
  13. dsms
    Mostly black DD finishing pad, some areas need a little more bit some green was used first.
  14. Reflect
    Looks fantastic Dave, I always loved those LS series. How do you manage running the DA to apply LSP around the tight spots, like door handles and mirrors and that sort of thing? Do you go back over it with a hand applicator?
  15. Auto Concierge
    Car looks awesome!!(again...)
  16. dsms
    Machine every inch that I can (safely) and using a 100ppi foam hand applicator for areas like the license plate holder that can be machines easily
    Thanks Bob, again!
