DG Steps, 601 flash curing 501?
Discussion in 'Car Detailing Product Discussion' started by estcsts2000, Jun 16, 2010.
  1. sal329
    sal329 Nuba Guru
    If you used p21 cleanser I would skip 501 unless you are using it as your LSP. Just put 601 on then apply 111 or 105 let haze and buff off. I always use a QD or spray wax to do a final wipe and make sure all wax or sealant is buffed off
  2. Mindflux
    Mindflux Welcome to Detailing
    I can't seem to get ahold of an 105 around here. I have 501 and ordered some PBA 601 (at carquest) but all they have is 101 and 111. I'm afraid the cleaning properties in 101 would negate the use of 601 applied before it.
    Thoughts?
    By the way my local A-Line auto had 1/2 gallons of DuraGloss shampoo for $10.99. that makes a gallon $22 bucks. Less than Autogeek! #101 and #111 were also 5.99, which sells for about $10 direct at DuraGloss or even at Autogeek.
  3. richy
    No there will be no issue. In fact, that's why it's beneficial...it bonds to whatever is beneath it.h
    Use 111 then. I just find 105 is easier to remove that's all. That's why I prefer it. Don't forget if you order directly from DG, the stock is fresh and the shipping, regardless of the order, is $5.
  4. Mindflux
    I am going to just do 601 followed by 501. The guys at DuraGloss claim it'll work in spite of 501's cleaning abilities. (same for 101)
    Also I've never seen anything by DuraGloss claiming 601 flash cures anything.
