Detailer's Domain's 2016 BMW M2 in Long Beach Blue
Discussion in 'Detailing Bliss Lounge' started by detailersdomain, Nov 9, 2016.
  1. Woob
    Woob Jedi Nuba
    good lord. what a build.
  2. detailersdomain
    Eventuri Carbon Fiber Engine Cover for the BMW M2 F87
    I picked this up from the team at IND not sure if it's on the site yet but I believe they have them in stock.
    Everyone can use more carbon fiber.....
    Items that you will need - BMW Logo - part # 11 14 7 788 967 (this is not the same part number on our BMW M2 Engine cover)
    You will also need to pull the rubber grommets (total 3) out of the oem engine cover and put them into the carbon fiber cover as well as the insulation. Pics below.
    Since I'm a bit ocd I went ahead and used the Rupes Ibrid Short Neck with the Rupes Yellow Pad and Jeffscar Micro Finishing Polish (coming soon) to remove some of the hazing left behind from possibly the wetsanding and compounding after the clear coat was sprayed. I went ahead and polished it out to remove the haze and bring out the shine. Following it with 2 layers of Nanolex SI3D HD ; )
    Haze on the CF Engine Cover
    Polishing the haze out
    I opted to remove the Eventuri decal.....
    Probably should have removed them first before polishing
    BMW Roundel Emblem
    Used Nanolex EX to prep the CF Engine Cover for Nanolex SI3D HD
    A nice thick coat of Nanolex SI3D HD goes on
    After
    Swapping out the grommets and insulation from the OEM Engine Cover
    OEM Engine Cover
    Back of Engine Cover with Rubber Grommets and Insulation
    Pulling out the insulation from OEM Cover
    Back of the CF Cover
    Installed rubber grommets
    Without insulation
    Before with OEM Engine Cover
    https://www.youtube.com/watch?v=KdT8ZtADyMY
    rwisejr likes this.
  3. detailersdomain
    Removing the rubber nib, removing knobs, removing hair off your tires.
    I used one of the razor blades that we use for clear film installation to clip them off, some use nail clipper or box cutters all good.
    a nice clean look. something so small and such a big impact ; )
    rwisejr likes this.
  4. detailersdomain
    and so the guys at Rogue Engineering just informed me that my brakes are in ; )
    Product Description:
    (F) 6-Piston Monobloc Calipers | 380x34mm (15') 2-Piece Discs | Type 3 | Color: Yellow
    Part number: 1N3.9045A5
    (R) 4-Piston Monobloc Calipers | 380x28mm (15') 2-Piece Discs | Type 3 | Color: Yellow
    Part number: 2P3.9044A5
    Can't wait to get these on the car
    Ready to get them on
    Removal of stock
    Installed Front and Rear
    More pics to come
    rwisejr likes this.
  5. detailersdomain
    Removal of stock
    Afters
    rwisejr likes this.
  6. detailersdomain
    More shots of the Brembos on the car
    rwisejr likes this.
  7. okay65829
    okay65829 Active Member
    It's so pretty it's scary!
  8. detailersdomain
    thanks I love this car
  9. detailersdomain
    A few dirty shots.
  10. rwisejr
    rwisejr DB Forum Supporter
    Outstanding new ride Phil. Love all the sweet upgrades . Enjoy it in good health.
  11. detailersdomain
    thanks I appreciate it.
    rwisejr likes this.
  12. Mbkite
    Mbkite Member
    Awsome car 4 an awsome guy..
  13. detailersdomain
  14. S4 John
    S4 John New Member
    Long beach never looked better! I want an M2 so bad.
  15. detailersdomain
    The dash camera installation -
    I would recommend a pro doing this install, even though I'm sure I was capable of doing this install I was glad I left it to our in house pro installer at our shop. It's a little more in depth than hardwiring a radar.
    Winy Insight FX - Dash Camera
    Unboxing.
    Proper tools
    Removing some panels to get some easy access to hardwire the dash cam.
    Removing the trim pieces around the mirror
    Testing for ignition - on/off
    Wires/Fuses
    Ground
    Nice and tidy.
    Tucking in the wires (not the best photos)
    Installing the micro sd card
    Mounting the front camera
    Rear camera mounted
    Final install photos - more to come
    [​IMG]Detailers Domain, on Flickr
  16. detailersdomain
    Got these in and got them installed, I think it looks great!
    Acexxon Honey Comb Rear Bumper Grills
    Before
    [​IMG][/url]
    After
    [​IMG][/url]
  17. detailersdomain
    When I saw the following threads I was inspired to get this done to the M2. I thought it would not only look good but would be a great way to do some OEM plus mods to make the car a bit tighter.
    Steve_Jr's thread on his F30 - http://f30.bimmerpost.com/forums/showthread.php?t=1234698
    And this one from Europe
    http://www.babybmw.net/forum/viewtop...710096a1ec1bf5
    I believe the below are all the parts needed to do the M3/M4 F8x Carbon Fiber Strut Mod on our M2's.
    Hex Bolt - 11-28-7-839-136 x 6
    Guide Sup - 31-30-7-853-702 x 2
    Hexagon S - 094C3 - 07-11-9-904-141 x 6
    Torx Screw - 31-10-6-859-809 x 10
    Fillister - 07-14-7-162-464 x 2
    CFRP strut front end 1EA : 51618061631
    Alloy Strut brace (left steering) 1EA : 31122284855
    The tricky part was hoping that the eventuri carbon fiber air intake would fit.
    Jesse my mechanic took the hold out and reversed the bolt on top to make it fit nice and tight put some padding under the high points that would touch or potentially rub.
    All in nice and tight and looking good.
    Some cutting was needed on the cover and some trim pieces
    More pictures to come.
  18. detailersdomain
    it's been a bit of time.....update
    Got Ben at Rogue Engineering to flash my M2 with the VF Hex Tune.
    HEX Tuning Advertised Stage ONE: 20-30WHP / 50-60WTQ
  19. Socal Brian
    sweet upgrades and very nice thread! Enjoy Phil!
  20. Steve Vozzo
    Steve Vozzo New Member
    Just joined the thread. Good post!
