Current Deals and Promotions @ DetailersDomain.com
Discussion in 'Detailers Domain' started by detailersdomain, Nov 6, 2007.
Free Shipping over $50 or a Prom Code?
  1. Free shipping over $50
    71.4%
  2. Promo Code of 10% off
    28.6%
  1. Meticulous-Detail
    detailersdomain likes this.
  2. BlakRam
    BlakRam Any Rag Vehicle Washer
    BlakRam DB
  3. plowery21
    plowery21 New Member
    plowery21 from Detailers Domaine/Detailing Bliss
  4. NickBlaine
    NickBlaine Any Rag Vehicle Washer
    nickblaine DB
  5. hostage1978
    hostage1978 DB Forum Supporter
    Hostage1978 from DB
  6. Kfrey
    Kfrey New Member
    I feel lucky!!!!!
  7. punk0208
    punk0208 Virgin Detailer
    from VWVORTEX DETAILING FORUM !!
  8. Brunkel
    Brunkel Virgin Detailer
    Brunkel, from golfmk6 fourm.
  9. chadg
    chadg New Member
    Chadg from Camaro5.com
  10. dub*man
    dub*man Virgin Detailer
    dub*man from vwvortex!
  11. Rod
    Rod New Member
    I would really like to win here, thanks for the link and I will be reading at the forum for some time now.
    Rod from Golf MK6 forum
  12. ModernBlue9
    ModernBlue9 New Member
    ModernBlue9 from DB, autogeek, cherokeesrt8 and ls1
  13. ghstrdr
    ghstrdr New Member
    ghstrdr from DetailingBliss
  14. Ronaldo
    Ronaldo Virgin Detailer
    Ronaldo from Brazil, I need
  15. SpeedFreakDetail
    SpeedFreakDetail New Member
    SpeedFreakDetail from DB
  16. hbanzon
    hbanzon New Member
    Hbanzon from DB
  17. detailersdomain
    http://www.detailingbliss.com/topic/28844-anti-frost-winter-washer-fluid-mixing-tips/
    Hey folks, we've been getting questions on how to properly mix Anti-Frost Winter Washer Fluid Concentrate to achieve the desired freeze protection. Here are a few tips to help you out.
    1. Let's use the mixing ratio for -15° F as an example which requires you to mix 1 part AF + 1 part water (or 1:1). This means mix equal amounts of each liquid together to produce the final product, which in this case is 2 liters of washer fluid.
    So that would mean mixing 1 liter of AF (the whole bottle) + 1 liter of water (just fill up the now empty AF bottle with water).
    That's just over half a gallon of washer fluid. Most washer tanks are between 1-1.5 gallons in capacity
    2. This is important... We are assuming your washer tank is EMPTY when you add the finished mixed product into the washer tank. If you have washer fluid in it already, keep in mind that it will dilute whatever Anti-Frost solution you mixed and will weaken the freeze protection level (the more you dilute Anti-Frost, the weaker it becomes).
    Solution: You will need to empty your washer tank or use little to no water when making the solution based on how much regular washer fluid you already have in the tank - we know, it's almost impossible to tell. Although, you should always mix little by little to get the right freeze protection without making the solution to soapy.
    3. If you have an empty 1 gallon jug (ex. a milk or water jug) lying around, mix a solution of AF in there first and keep it on hand for when you need it.
    4. Anti-Frost mixes with any brand of washer fluid without any issues.
    Hope this helps. Let us know if you have any questions or if you have any suggestions you'd like to share.
    In the meantime, if you are getting hit by this winter storm, bundle up, stay safe and keep warm!
  18. Rocket01
    Rocket01 Birth of a Detailer
    rocket01 - DB
  19. KKY
    KKY Virgin Detailer
    KKY from DB.
  20. jogger
    jogger New Member
    jogger from mbworld
