Current Deals and Promotions @ DetailersDomain.com
Discussion in 'Detailers Domain' started by detailersdomain, Nov 6, 2007.
Free Shipping over $50 or a Prom Code?
  1. Free shipping over $50
    71.4%
  2. Promo Code of 10% off
    28.6%
  1. bmw5541
    bmw5541 Any Rag Vehicle Washer
    Hey Phil,
    I finally joined DB and subscribed.
    It was nice seeing you the other day!
  2. Goone
    Goone Virgin Detailer
    can you apply 2 code? free shipping for order over 75 and additional 10% discount?
  3. detailersdomain
    one code per order
  4. detailersdomain
    working on some good ones for you all now.
  5. agpatel
    agpatel OD On Detailing
    yepppppie :)
  6. rfinkle2
    rfinkle2 DB Forum Supporter
    oh yeah! ... i mean oh no! ... i'm saying oh yeah! ... my pockets are saying oh no!
  7. detailersdomain
    Just like the title states save 20% plus off selected items!
    Stock up on Collinte! Save 20% off list!
    The Foam Gun is back in stock and we have 2 specials!
    Gilmour Foam Gun - $49.95!
    Uber Foam Gun Kit - Now with the Uber Wool Wash Mitt - Save 30.77!
    Uber Wool Wash Mitt V2 with a Free Prima Mystique - Intro Price of $29.95!
    Don't forget
    Stock up on Uber Microfibers 25% off
    Stock up on Uber Foam Buffing Pads 15% off
    Prices reflect the above!
    Details
    Promo Starts: Now
    Promo Ends: 2/14/2011
    Enjoy!
  8. detailersdomain
    Just a reminder.
  9. detailersdomain
    Kwazar Promotion Coming Up
    Stay Tuned!
  10. detailersdomain
    Hey all I've been getting many requests for the Kranzle Pressure Washers.
    I'm going to propose this group buy.
    I will need 5 to make this one fly.
    Take a look at the 3 deals. (Promo Codes will not be accepted)
    Kranzle K1600 - List Price $975.00 ----> GB Price $599.00 Free Shipping within 48 States
    The Kranzle K 1600 Cold Water Electric Pressure Washer is an industrial grade pump. The pump design gives multi-hour bypass and run-dry capability preventing accidental pump damage. The Kranzle pressure washer comes with an adjustable pressure unloader. This model is great for light commercial duty use on hotel and buildings, HVAC maintenance, screen-printing, or on your home, boat, or vehicle.
    Features:
    Self Priming: This pressure washer is able to independently pump water from most water sources (buckets, ponds, etc.) and does not require water to be pumped into if from a hose
    Pump design gives multi-hours bypass and run-dry capability preventing accidental pump damage
    Professional gun-jet lance
    33' wire braided hose
    Gauge
    Safety coupler screw connections
    Knife-jet nozzle
    Optional low pressure soap injection
    Applications:
    Light Commercial Duty:
    Hotel and buildings
    HVAC maintenance
    Screen-printing
    Boating or vehicle
    Specifications:
    1,600 PSI
    1.6 gallons per minute
    Cleaning power: 2720
    Industrial grade pump
    Adjustable pressure unloader
    110 Volts, 14 amps TEFC electric motor with 25' cord
    Steel hand carry frame
    Inlet water filter
    Shipping weight: 42 lbs
    Dimensions: 7" H x 18" W x 13" D
    Kranzle K1120T - List Price $1300.00 ---> GB Price $799.00 Free Shippping within 48 States
    This medium sized pressure washer is the perfect washer for everyday commercial use. It comes with the Dirt Killer nozzle which doubles the cleaning efficiency. The K 1120T Mini Power Pack Cold Water Electric pressure washer design gives multi-hour bypass and run-dry capability preventing accidental pump damage. There is a built in hose reel that comes with a 50' wire braided hose. The pressure washer has exit side chemical injection and comes with a professional gun-jet lance and safety coupler screw connections.
    Features:
    Pump design gives multi-hour bypass and run-dry capability preventing accidental pump damage
    Dirt Killer nozzle doubles cleaning efficiency
    Built-in hose reel
    50' wire braided hose on hose reel
    Exit side chemical injection
    Gauge
    Knife-jet (high-pressure wash/soap)
    Dirt Killer turbo nozzle
    Applications:
    Hotel and buildings
    HVAC maintenance
    Screen-printing
    Boat or vehicle
    Specifications:
    1,400 PSI
    2.0 gallons per minute
    Cleaning power: 2,800
    Kranzle AZ industrial grade pump
    Kranzle adjustable pressure unloader
    110 volt, 15 amps TEFC electric motor with 25' cord
    Steel frame with plastic cover that holds all accessories
    Inlet water filter
    Shipping weight: 70 lbs
    Dimensions: 32" H x 13" W x 12" D
    Kranzle K2017T - List Price $1900.00 --> GB Price $1299.00 Free Shipping within 48 States
    A light commerical pressure washer that packs a punch, the K2017T with GFI Space Shuttle Cold Water Electric Pressure Washer from KranzleUSA is a portable pressure washer that possessed the cleaning power of 2,805. This is perfect for pool, boat, house, or vehicle cleaning. This pressure washer is equipped with ground fault interrupter that helps prevent shocks and the design of the washer gives multi-hour bypass and run-dry capability preventing accidental pump damage and it is also freeze-proof. This pressure is going to last. It comes with a 50' wire braided hose on hose reel, professional gun-jet lance, gauge, and knife-jet (high pressure wash/soap) nozzle.
    Features:
    Pump design gives multi-hour bypass and run-dry capability preventing accidental pump damage and is freeze-proof
    Hose reel with 50' high pressure wire braided hose
    Ground fault interrupter (GFI) prevents shocks
    Exit side chemical injector
    Gauge
    Knife-jet (high pressure wash/soap) nozzle
    Applications:
    Hotel and building
    Screen-printing
    Pool
    Boat or vehicle
    Specifications:
    1,650 PSI
    1.7 gallons per minute
    Cleaning power: 2,805
    Kranzle APG industrial grade pump with 10 year manifold warranty
    110 volt, 15 amps, TEFC electric motor with 35' cord and ground fault interrupt (GFI)
    Steel frame with plastic that stores all accessories
    Inlet water filter
    Shipping weight: 100 lbs
    Dimensions: 38" H x 15" W x 15" D
    List of 5 to make this fly
    1.
    2.
    3.
    4.
    5.
  11. detailersdomain
    We were given the green light to run a special on the Kwazar Mercury Pro and Venus to all our members.
    [video=youtube;PYI0LLlcFLA]http://www.youtube.com/watch?v=PYI0LLlcFLA[/video]
    [video=youtube;TCFPWVJHU3g]http://www.youtube.com/watch?v=TCFPWVJHU3g[/video]
    This will be for a LIMITED TIME.
    Starts Today
    Ends: Feb 18, 2011
    Take a look at the offerings.
    Kwazar Mecury Pro + 0.5 Liter - List Price: $15.99 - Promo Price: $12.99
    Kwazar Mercury Pro + 1 Liter - List Price: $17.99 -Promo Price: $14.99
    Kwazar Venus Pro + 1.5 Liter - List Price: $25.99 - Promo Price: $20.99
    Kwazar Mercury Pro 0.5 Liter 3 Pack - Price: $47.97 - Promo Price: $34.95
    Kwazar Mercury Pro 0.5 Liter 6 Pack - Price: $95.94 - Promo Price: $69.95
    Kwazar Mercury Pro 1 Liter 3 Pack - Price: $53.97 - Promo Price: $39.97
    Kwazar Mercury Pro 1 Liter 6 Pack - Price: $107.94 - Promo Price: $79.95
    Let me know if you have any questions.
  12. detailersdomain
  13. kyoshiro
    kyoshiro DB Forum Supporter
    typo 2nd last link, 3pack not 6
  14. Chaseme
    Chaseme DB Forum Supporter
    Those things can really build some pressure.
  15. kdude
    kdude Jedi Nuba
    i like the different colours too.
  16. rwisejr
    rwisejr DB Forum Supporter
    Hey Did these start shipping yet ?
  17. detailersdomain
    we did not get them yet, we should have them next week.
  18. rwisejr
    Ok just checking !!!!!!!!!!!
  19. detailersdomain
    trust me it will go out asap, I can't wait to get mine either.
  20. kyoshiro
    i cant wait for fund recupperations so i can order mine LOL
