Current Deals and Promotions @ DetailersDomain.com
Discussion in 'Detailers Domain' started by detailersdomain, Nov 6, 2007.
Free Shipping over $50 or a Prom Code?
  1. Free shipping over $50
    71.4%
  2. Promo Code of 10% off
    28.6%
  1. detailersdomain
    so 7 inch on a 5 inch backing plate?
  2. :graduation: Kevin Brown Dropping Knowledge :applause:
  3. Yes Kevin, I have the same question :shead:
    Are we talking DA or Rotary here :shead:
    Phil, put me down for 2 each. Just not sure what size untill Kevin instructs me forward :hmph:
  4. Kevin Brown
    Kevin Brown Buff Daddy
    I wouldn't use them with a rotary for the reasons outlined previously.
    Orbital, random orbital, forced rotation orbital, YES.
    As for which diameter backing plate to use... use a plate that will support the pad as much as possible.
    With a 7" pad, I use a backing plate that measures 5-7/8" across. It works just fine.
  5. Thanks Kevin. I always feel so stupid after talking with you :paranoia:
    P.S. Tell Annie, Trouble sends her regards :peace:
  6. Phil, you wouldn't happen to carry 5-7/8" BP's would you :shead:
  7. Kevin Brown
    O-M-G.... I will! :yikes:
  8. Kevin Brown
    Checked your site, Phil, but not sure if I saw all the plates you offer.
    I am sure you've got one available on the site, or access to them through one of your brands.
    Pretty much any typical backing plate made for 6" sanding discs will work just fine.
    I have used:
    • Meguiar's S6BP
    • Mirka 106GG
    • Mirka 916SGV
  9. detailersdomain
    Thanks again Kevin.
    The item is now up for pre-ordering.
  10. detailersdomain
  11. Yes, it is I :giggle:
    Order 20635 placed :p
  12. detailersdomain
  13. Pats300zx
    Order 20638 placed :)
  14. MelF1fan
    MelF1fan Birth of a Detailer
    Very nice, might look into getting some of these. Might make me use my old PC again. Wonder with the proper technique interesting to see what kind of time savings this vs. Rotary correction.
    Even though i don't have one, yet, do these pads work any good with the Flex 3401 ? The bigger sized pads i assume are recommended with the Flex.
  15. detailersdomain
  16. detailersdomain
    Okay so I've decided to run this one till the end of the year and assess from then.
    So enjoy!
    A FLAT SHIPPING RATE OF $8.88 ON ORDERS UNDER $149.95
    FREE SHIPPING ON ORDERS OVER $150.00.
    OFFER ENDS 1/1/2011
    You will be able to combine this with any offer.
    NOTE:
    - Shipping promo good for the lower 48 States
    - You will be able to combine this with any offer.
    - There will be other options so if there is a lower rate it will be presented.
  17. Chas
    Chas DB Forum Supporter
    That's awesome Phil!
  18. Legacy99
    Legacy99 Wax on..Wax off
    Will you ship flat rate to Hawaii?
  19. :shead:
  20. GDAL
    GDAL Guest
    Thanks Phil ... that's awesome.
