I'm wondering if it's ok to Opti Gloss Coat on top of the clearbra? Or it's better just to use sealant/wax on top of it instead? Also, could one lightly polish the clearbra? Like using the Sonax 4/6 with a green uber pad? Thanks in advance guys.
You can apply Opti Gloss Coat on top of film that should not be a problem. You can wax or seal the film as well. Typically most manufactures do not want you to polish out film - that being said we have polished film. Best to check with the manufacturer of the film.
Thanks for the advice. I'm thinking to use the Sonax 0406 & a green uber pad (or a white pad) to polish the film just for clean & brightening before applying the coating on top.
Applying a nano coating on top of the clear bra will prevent the PPF from fading/discoloring. It'll also add another layer of protection. We do it all the time with our Nano-Resin. Go for it!
