Clear Automotive Protective Coating (A.K.A. Clear
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by togwt, Jan 24, 2009.
  1. togwt
    Clear Automotive Protective Coating (A.K.A. Clear Bra)
    A sound understanding of the proper technique and the correct process will produce excellent results even with a mediocre product. A quality product used without the proper surface preparation or application technique will never obtain a satisfactory result. Using the proper methodology (surface preparation, using a quality product, along with the correct application technique) will ensure an excellent result.
    Some methods described may be beyond the capabilities of the average detailer or enthusiast; in this case we strongly encourage the reader to consult a professional detailer or body shop concerning the matters discussed herein. The writer assumes no responsibility, expressed or implied, due to misuse or misinterpretation of the information or methods used, or for any vehicle damage or injury that may occur due to the suggestions and information offered.
    Proceed with this in mind; the products you use constitute a very small factor in the equation. Methodology and technique constitute 95%; the reasoning behind the choice of quality products is to eliminate any limiting factors, thus enabling you to place emphasis on technique used.
    Developed by the 3M Company, Scotchgard™ Paint Protection Film, (SGPPF6) 99.5% optically clear 8Mil (0.008-inch) film designed to reduce stone chipping and bug damage on painted surfaces. It’s a blend of acycloolefin, copolymer and a thermoplastic urethane, a tough, conformable material that is covered by a clear coat layer.
    This rugged transparent material will not crack, shrink or peel over time and it resists yellowing, the film and clear coat layers contains a protection to counteract harmful ultraviolet (UV) and infrared (IR) radiation that can cause the surface to occlude (cloud) Testing from 3M reveals that the material will deflect road debris without film damage at up to 60MPH with the standard film. Mid-tone coloured cars, silver, reds, greens or gold’s, the film absolutely disappears into these colour (Product Specs -http://www.armourfend.com/images/3M.pdf )
    Ensure that there are no surface imperfections before installation. It is important to remember that paint protection film application is not considered to be a do-it-yourself project. For best results, professional application is recommended.
    Clean and maintain its surface with ( Z-8™ Grand Finale Spray Seal) or a plastic cleaner (Plexus® Plastic Cleaner, Protectant and Polish) start at the centre and work outwards, do not use a foam pad / rotary buffer / abrasive compound on the plastic surface or detailer’s clay as it will cause micro-fine surface scratches.
    To remove minor scratches in the film (tape the edges of the auto mask when polishing the vehicles paint ) Use Menzerna Final Finish Polish / Super Finish (PO106FA) and a (POC) Gold Concours Finishing foam pad 1000 RPM do not use any downward machine pressure and maintain a fast linear motion. It is important not to apply a lot of pressure to the film as this may lead to burning of the surface. Use a Q-tip and some isopropyl alcohol to clean out the edge (See also 3M website- 3M Worldwide)
    Maintenance and Care1. To clean stains use a citrus based cleaner (P12S Total Auto Wash) polish the paint and the clear plastics separately, tape the edges with masking tape. It has a clear coat so it can be cared for like a clear coated paint; use Zaino or Klasse as they will dry ‘clear’. Use Z-14 Plastic Magic Cleaner & Polish™ or Plexus® Plastic Cleaner, Protectant and Polish for maintenance and to remove any finger marks / smudges (avoid the use of abrasives)
    2. What can be done about wax build up along the seams and how can I avoid it?
    Wax will leave a white line on the seam, it is recommended not to wax over the seams and wax the film and uncovered portions separately to keep from wax build-up. If you accidentally wax over the seam, just use a wet towel and rub it off. Another caution is to avoid buffing over the seams, which creates a noticeable wax line as well.
    3. To remove ‘clouding’ from the paint under the clear bra; the suns heat or a hairdryer will remove it.
    4. Removal -it is not difficult to remove, apply heat to a corner with a hair dryer (not a heat gun) and work slowly to avoid breaking / tearing the vinyl (like any applied vinyl, the longer it’s been applied the more difficult it will be to remove) work slowly and be patient.
    Adhesive removal
    a) Detailer’s clay and /or 1:1 Isopropyl Alcohol / distilled water
    b) 3M Citrus Base Spray Adhesive Remover – a citrus-based, solvent-free adhesive remover leaves surfaces clean and dry with no residue. Removes tape residue from masking, foam or duct tape, clean, fresh citrus scent - not recommended for use on plastic
    Note:
    a) If the film is properly applied to a fully cured painted vehicle, it can be removed, usually in one piece, without damaging the paint surfaces beneath the film by pulling the film at an angle not straight up.
    b) Repainted vehicles, paint must be thoroughly dry and completely cured before any attempt to apply film to the vehicle is made, in order to avoid film bubbling (solvent pop) due to paint out-gassing. Check paint body shop and / or paint manufacturer's instructions for recommended cure time and method.
    For further information see -
    3M Protective Film Clear Bra Test - Automotive Articles .com Magazine
    • 3M FAQ- Frequently Asked Questions 3M US paint protection film films clear bra bras shield shields stone stones rock rocks chip chips guard guards protect protects answer answers help helps find finds out how to
    •X-Pel UK Area Dealers- XPEL Technologies Corp.: International Dealer Search
    • X-Pel US by State Area Dealers- Paint Protection Film - XPEL Technologies Corp. and use the Zip code locater
    Alternative products
    a) An optically clear product (recommended) Invisible Patterns
    b) Spray on Shield, from Dupli-Color, provides temporary spray-on protection for your vehicle where bugs and road grime can do damage. It’s ideal for the front end, rear quarter panel and rocker panels. Spray on Shield as a temporary bra for long road trips, quick mud flaps or as a bug guard. Shield sprays on easily and dries in less than a minute. And best of all, it stays on until you wash it off. You can power wash it off or use soap and water. Rain, snow or moisture in the air won’t affect it. This product leaves no residue on a vehicle’s paint. Give your vehicle the protection that it deserves with Shield. Shield
    Clean and maintain the surface with ( Z-8™ Grand Finale Spray Seal) or a plastic cleaner (Plexus® Plastic Cleaner, Protectant and Polish) start at the centre and work outwards, do not use a foam pad / rotary buffer / abrasive compound on the plastic surface or detailer’s clay as it will cause micro-fine surface scratches.
    4. Removal -it is not difficult to remove, apply heat to a corner with a hair dryer (not a heat gun) and work slowly to avoid breaking / tearing the vinyl (like any applied vinyl, the longer it’s been applied the more difficult it will be to remove) work slowly and be patient. Detailer’s clay and /or 1:1 Isopropyl Alcohol / distilled water to clean any adhesive residue.
    Information resource
    Automotive Detailing Inside & Out, A Knowledge Base for the Perfectionist– by Jon Miller
    © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved​
    Copyright Protection and intellectual property rights-© This work is registered with the UK Copyright Service
    All original material is copyright, unless otherwise state (1) it may be copied and distributed for non-commercial purposes only provided that you retain all copyright and other proprietary notices contained in the original material, (2) the information is copied in full with no changes unless prior written agreement is obtained from TOGWT, and a reference to © TOGWT ™ is included, any unauthorized use of these materials may violate copyrights and/or trademarks
  2. eyezack87
    eyezack87 Guest
    Very nice. I've been looking for a way to help my clients with this :)
