can i steam clean alacantara?
Discussion in 'Interior Car Care' started by slanguage, May 25, 2013.
  1. slanguage
    I have a 2006 S2000CR that was just dropped off for an interior job. I dont have cleaner for the alacantara. So i was wondering if it was safe to steam that section of the seats.
    Thanks,
    -Roger.
  2. togwt
    Using dry steam vapour
    (A-Aniline / Non-Coated)(Alcantara®) (P-Protected / Coated) A system that produces a high temperature, low moisture vapour that contains only 5% to 6% water and is much less dense than air, a steam vapour system is equipped to safely produce thousands of gallons of live dry steam using only about 1.5 quarts of water per hour.
    With temperatures (212.0F) hot enough to kill bacteria and germs, emulsify grease and oil as well as other surface contaminants. These units are best suited for light cleaning (covered leather, Alcantara or fabric upholstery) maintenance, and spot removal.
