Buying A Rotary
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by run115, Dec 8, 2009.
  1. kc1337
    kc1337 Obsessive Detailer
    I thought the 3403 would only recommend a maximum pad size of 6.5inches?
  2. 911Fanatic
    May I ask why you would use a pad larger than 6.5"?
  3. kc1337
    I was just wondering if the 6.5 inch limit is a very big deal since there are pads bigger than 6.5inches. I guess thats not the case then since not many use them?
    Sorry I am a bit woozy from studying exams.
  4. Legacy99
    Legacy99 Wax on..Wax off
    So is there a problem using the new 3M 8" dual pads with the 3403?
  5. rwisejr
    rwisejr DB Forum Supporter
    Its not recommened to use pads larger than 6.5 as it can and most likely will overheat the unit
