Better than Ultrafina?
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by kenny1775, Sep 26, 2008.
  1. kenny1775
    kenny1775 Jedi Nuba
    Update: Micro Polish just arrived :woot:
    E-Shine rocks when it comes to quick delivery (Big-ups' to Chris) [​IMG]
    I'll let you guys know how this stuff works after I try it out this evening [​IMG]
  2. kenny1775
    kenny1775 Jedi Nuba
    Update:
    I tried a 50/50 on the trunk of that black Accord... SWEEEEET!!!!! [​IMG]
    I think it's too subtle to pick up with my camera, but a definite improvement :afro:
  3. kenny1775
    kenny1775 Jedi Nuba
    Yeah, I tried with the camera and it wasn't sensitive enough to pick up the difference :picture: sorry gents.
    I assure you though, there was indeed quite a difference :righton:
    I wouldn't put these two polishes in the same category... Ultrafina has more cut than Micro Polish :thinking: As a matter of fact, if I was doing a 2 step on a newer car with very light swirling, I would probably start with the Fina' and then jewell to perfection afterwards with the Micro'
  4. kenny1775
    kenny1775 Jedi Nuba
    Update: Just for the heck of it, I decided to go over the trunk of that Accord again with the Micro Polish to see if I could bring out some more gloss... about 45mins of jewelling later guess what???
    It got stepped up another notch [​IMG]
  5. kenny1775
    kenny1775 Jedi Nuba
    Update: This is turning into an interesting research project...
    Just for S&G I decided to give the Ultrafina another shot on the Accord to see if I was being unfair by spending so much time with the Micro Polish in the jewelling process.
    It turns out I may have :thinking:
    You see, I used the Micro Polish on top of the original Ultrafina area (for a 50/50) and it showed an improvement. What I did not try initially was re-working the half without the Micro Polish to see if there was anything more that the Ultrafina could give me.. and when I did, it did :thud:
    I think I may be back to square one when it comes to seeing for myself which one of these two polishes is actually better.
  6. kenny1775
    kenny1775 Jedi Nuba
    PO85RD is still haunting me [​IMG]
    I want to try it out soooooooo badly :shakehead:
  7. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    You will be very happy when you do.
  8. kenny1775
    kenny1775 Jedi Nuba
    Every car that I've seen it used on seems to have a very unique "shimmer" [​IMG]
    Maybe I'm just going nuts [​IMG]
  9. Asphalt Rocket
    To me it is the gloss, then again it depends on your definition of shimmer.
  10. kenny1775
    kenny1775 Jedi Nuba
    Probably the same thing... as if there was a perfectly smooth layer of baby oil on the paint... a masterpiece [​IMG]
  11. Asphalt Rocket
    I can work with that.
  12. Wendell inc.
    Wendell inc. Birth of a Detailer
    Does 85RD fill because i know UF does. My 85RD arrived today along with my CR spotless a few pads and that new menz polish.
  13. Asphalt Rocket
    All polishes fill from what I hear.
  14. matrix_808
    matrix_808 DB Supporter
    so which is better 85rd or the PO87MC?
  15. Dream Machines
    Dream Machines Jedi Nuba
    the oils (parrafin usually), cause some unintentional filling, just make sure that 85RD, 106FF or 87MF/MC is used once all the defects are completely gone
    Prepsol wipedowns during correction process, before enhancement process with RD etc are essential for guaranteed 100% flawless finish
  16. kenny1775
    kenny1775 Jedi Nuba
    Right now that's the million dollar question Matrix...
    So far the answer is "it depends on how hard the clear coat is"
  17. kenny1775
    kenny1775 Jedi Nuba
    Don't worry folks... I'm going to find the answer... no matter how long it takes [​IMG]
  18. Wendell inc.
    i wouldn't say that ALL polishes fill but i would say under the right circumstances some or most do. I havent witnessed m105 fill or some other polishes. And prep sol wipedowns do not always remove all the filling. I hope 85RD fills EXTREMELY little!
    And i hope to find out today! YAY
    ,Daniel
  19. budman3
    budman3 Birth of a Detailer
    If you use 85rd as a jeweling polish vs. a corrective polish then you have nothing to worry about, granted all of the defects are removed prior to the 85rd ...
  20. Wendell inc.
    Absolutely. Hopefully this new powerfinish will be a good in between for SIP and 85RD!
    What would you recommend before 85RD but after SIP?
