Background: Have a herniated disc in my neck that has taken away feeling and strength in my left arm with an added bonus of my right arm being tired most of the time since I'm using it a lot more. Current Equipment: PC 7336 Question: Is there any current DA out there that would be easier for me to use? Less Vibration and/or Less weight? So far on another forum the Cyclo has been recommended as well as vibration reducing gloves.
looks like a cyclo will be your best bet with your conditions. because all DA buffers vibrate.... The Griots garage DA has less vibration than a PC 7424xp but still vibration.
Think I'll give it a go with my PC before I start dropping change on something new then. Seems like it's all tradeoffs in getting something else.
As I tore my rotater cuff(Left shoulder) and I am "Lefthanded" the best thing is to try and keep your elbow below the plane on which you are buffing, also center up the pads good and the vibration will be less.......not eliminated but better. Griots DA is the best choice btw for many reasons.
i now use a simple ace tennis elbow strap before any polishing. place it very carefully on the bone at elbow and it helps tons. not too expensive either. i own all the above polishers and the cyclo is the smoothest but boy is it heavy. i now use the newer flex rotary that weight 2 pounds less and even is smoother than most da polishers. good luck
