Alcantara, Dinamica, Ultrasuede: Microsuede Care
Discussion in 'Interior Car Care' started by drbeasleys, May 2, 2017.
  1. drbeasleys
    drbeasleys New Member
    5 MICROSUEDE MUST-KNOWS FOR DETAILERS
    1. Heat is the biggest enemy of microsuede.
      • If you think you can clean this fabric with steam, think again. Overheating microsuede will permanently damage it, causing it to become crusty, dry, and hardened. Reviving this fabric is near impossible so if you have to use heat around it, don’t go any higher than 140 degrees.
    2. Don’t use just water to clean it.
      • You might think water is fairly harmless when used as a cleanser. Alas, it’s not. Water can stain microsuede. It can also create mold under the fabric if overused. Just avoid using it as a means to clean microsuede. Use Dr. Beasley’s Microsuede Cleanser.
    3. Don’t scrub it!
      • Sometimes cleaning means scrubbing, but definitely not when it comes to microsuede. We’ve heard of some people using tools like a pet stone on this fabric, only to completely and irreversibly ruin it. An interior brush used with very little pressure is plenty; you don’t need to use a lot of force.
    4. Using the wrong chemicals will fade microsuede.
      • Using an all purpose cleanser or the wrong type of cleanser on this fabric will change the look of it. Harsh chemicals can discolor microsuede, and there’s really nothing to be done to get it looking right again.
    5. Microsuede needs preventative care.
      • Don’t stop at cleaning this fabric. Once it’s properly cleaned, always protect it. Use Dr. Beasley’s Microsuede Protection to prevent future stains from penetrating the fabric.
