3M's new Car Wash soap is simply amazing!!!
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Paul Dalton aka Miracle, Dec 3, 2009.
  1. Paul Dalton aka Miracle
    Paul Dalton aka Miracle DB Pro Supporter
    Depending on humidity and temperature, between 5-30 mins, you need to buff it off just as it hazes over.
    Please let me know if you need anymore info or help.
    Kind Regards
    Paul Dalton
    Miracle Detail.
  2. Minicoop831
    Minicoop831 Birth of a Detailer
    I went ahead and ordered the 3m shampoo, Thank You Paul for the perfect timing as I have been looking for a new shampoo anyways
    the shampoo was $13 shipped pretty good deal, I will post up a review this weekend if it comes by Friday
  3. Paul Dalton aka Miracle
    Excellent, you won't regret it, its awesome !!
  4. kustomizingkid
    kustomizingkid Nuba Guru
    I was holding a bottle in my hand at Carquest, $8... passed at the moment as I didn't get home for another 12 hours and my car had to sit outside... didn't want it to freeze :D
  5. atomicfan
    atomicfan Any Rag Vehicle Washer
    Depending on the temperature i wait about 10-20min after i buff it out with the black swissvax towel as i find it is easier then with a microfiber.
    I used the cleaner fluid pro via rotary in june and put 2 layers of cr on it. I waxed the car iwith cr in October again without cleaner fluid pro or normal cleaner fluid.
    The problem ist that in the lower sections there is no beading action present after 2 months. On the hood and the roof the beading after 2 months slows down.
    I use the cg pro detailer for drying the car.
    The car gets about 1-2tkm per month. Actually it has 3 layers of cr on.
  6. VehicleDetail
    VehicleDetail Any Rag Vehicle Washer
    got mine in the post yesturday! god it does smell nice! similar to CG maxi Suds
  7. Dangler
    Dangler Birth of a Detailer
    I'm going to have to look into this and give the 3m wash a try. I also have Crystal Rock on my A4. The gloss that it has added is amazing. I use Optimums Car Wash at the moment, and the car beads the same since i put the CR on Which was back in July. I would hate to have the wax stripped off after a few months.
    The Day I applied Crystal Rock, an amazing wax. smells great too!
  8. Paul Dalton aka Miracle
    Where do you live?
    I would contact Swissvax directly, because I do about 2,000 miles per month and the van is still beading and it hasn't had a layer since July, although it could do with a clay.
    I also use Quick finish on a Crystal rock finish, I personally wouldn't use anything else.
  9. RNickolas
    RNickolas Obsessive Detailer
    thats why its not beading...most quick detailers kill your beading
  10. atomicfan
    I found that the CG Pro Detailer is beside of Field Glaze one of the best out there. I only use it as a drying aid.
    I live in Austria.
    I use the pro detailer on cars with divine, vintage or royale and have no problems.
    @Paul
    You do not use any drying aid?
    In winter i cannot rinse my car with an open hose i only have a mobi washer which leaves lot of water on the car. As it is very cold outside i need to dry the car assap
  11. Paul Dalton aka Miracle
    Drying aid? No, no need if your gentle and use deep plush drying towels, but then I guess everyone has there own way.
    I also used Zaino grand finale sometimes, and that is one mental product!! But I use this after I have dried it with compressed air and a drying towel.
  12. agpatel
    agpatel OD On Detailing
    Forgot about this post, but I tried it out this weekend and worked pretty well. Had a good amount of lubrication, good suds, cleaning ability was pretty good, and rinsed away clean. Hate the cap also Paul, so just took it off to pour out the soap and then put it back on.
  13. cleanfiend
    cleanfiend Jedi Nuba
    how does this soap compare to CWG?
  14. k1msta
    k1msta Guest
    i think this is a soft soap so it wont strip the lsp, not like cwg,cwc
  15. bvhbmw
    bvhbmw Birth of a Detailer
    FYI - this soap has a very thin consistency, almost like water. That doesn't make it any less effective, just so you know. Any foam gun or lance will easily flow this soap.
  16. agpatel
    Yeah, i tried to get some out from the lid and it split all over the bottle so i just took the cap off to pour it into the measuring cup.
  17. Esienmann_M6
    Esienmann_M6 Two Bucket System Washer
  18. agpatel
  19. oldcracker
    oldcracker Jedi Nuba
  20. Esienmann_M6
    Nice find Paul, Thanks I been looking for a safe soap for a while, Dodo's green soap is nice
    but that thing pours out of the bottle like its water! too much money as I go through more than
    1/3 of a bottle on each wash!
    Thanks agpatel
