3M Ultrafina Vs. Menz. 85RD
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by scheerspeed, Jun 4, 2008.
  1. J_Edwards
    J_Edwards Any Rag Vehicle Washer
    The edge with Ultrafina is simply its ease of use. Even though the finish isn't quite what you can get with the 85RD, it is such a pleasure to work with that I find myself grabbing it over the Menz almost every time.
    As for its finishing abilities, you can go from 105 to UF without any issues as long as you finish down the 105 correctly. I did a SS 88 930T yesterday that finished so great with 105 I almost didn't even need UF.
  2. SuperBee364
    SuperBee364 Birth of a Detailer
    That's been my experience, too, Fluxy. UF will clean up after compounding just as well as 106, but finishes out just a bit better. 85RD, OTOH, has no game at all for cleaning up after compounding, but is a *great* gloss polish. Just general rules, of course. On softer paints, 85RD can do some clean up, but not much.
  3. D&D Auto Detailing
    Just be careful with 106. Do your wipe downs.
  4. SuperBee364
    Oh, yeah, very good point. 106 and 85rd really like to conceal stuff.
  5. Mindflux
    Mindflux Welcome to Detailing
    Glad to see you decided to quit lurking. ;)
  6. SuperBee364
    You just never know when I'll show up out of the wood work. :) I've been lurking on and off since the board started last summer, but I figured I was enough of a loud mouth on Autopia that I wouldn't bother you guys here. :)
  7. Mindflux
    Your posts are well thought out and very helpful. I doubt anyone would be bothered by you here.
    :applause2:
  8. SuperBee364
    Thanks, man, I'll try not to be *too* obnoxious. ;)
  9. D&D Auto Detailing
    Glad to see you here Super.
  10. distrbd
    distrbd New Member
    I agree with mindflux ,glad you have finally joined us here.
  11. Dream Machines
    Dream Machines Jedi Nuba
    85RD because of it's extra gloss
    106 and 85RD don't conceal anything as long as you work them properly
    I always do a prepsol wipedown just to make sure and the result is perfection
    Sometimes adding some parrafin oil to the pad guarantee's no holograms
    Finally, what do people think of using 85RD with a red Lake country pad (after using 85RD with a blue pad and 106FF before that with a black)
  12. gmblack3
    In this thread, I used 085 and Ultrafina on the trunk. I had first polished with SIP and a green 5.5" green pad on the entire car.
    I first did 085 with a blue ccs pad on approx half of the trunk. I backed the car out into the sun and besides for some slight holograms from the SIP side, I could not tell much of a difference. Gloss and apprearance in the sun and the shade where very close.
    I then did the other part of the trunk with ultrafina and a clean blue CCS pad. Again in the sun and shade I could not tell a difference from 085 to UF.
    Was this due to the results I had got with SIP? :shrug:
    085 will get put away and kept for the occasion that UF does not work.
  13. MadOzodi
    MadOzodi Nuba Guru
    I'm curious what the veterans have to say about this. My understanding was that there was only a modicum of difference between the red and blue CCS pads. As such, I've purchased the different colors really for use as color coding; red for sealant X, blue for sealant Y. Anyone privy to the PPI specs on the two?
    How much more jewelling and glossing can 85RD with a red pad accomplish over 85RD with a blue pad and could the human eye really discern the difference?
  14. Todd
    Todd Banned
    So can UF, trust me.... UF just conceals a little longer :(
    Both polishes should only be used to remove light hologramming or when the paint is as close to perfect as possible. Expecting more from them is playing with fire, so to speak.
  15. D&D Auto Detailing
    Dont want to get off topic, but I agree 100%. All of these polishes (106FF, 85rd, UF) should only be used when the paint is as close to LSP ready as possible.
  16. Dream Machines
    Correct. UF definately fills
  17. Todd
    Todd Banned
    slight correction:
    Correct. UF definately has the potenital to fill like a mother f.cker!
  18. porta
    porta Jedi Nuba
    Matt, I have been trying to get in contact with you. Give me your email, I have some things that I would like to ask you.
  19. Usjdmtuner
    Usjdmtuner Wax on..Wax off
    i get better result with 85rd and i believe that it also removes minor swirls left from heavy polishing and it gives the best result... I dont have any preference on which to use but UF never gave me problem just the polish slings once in a while with high rpm...
  20. HPIA4v2
    HPIA4v2 Birth of a Detailer
    Just an observation.
    If both is comparable, PO85rd is around $40 while Ultrafina SE is $50. Also some online gives out 10-15% on Menz (haven't found Ultrafina online that gives out discount).
    So I'll probably stick with Menz.
