20 ways to speed up your Mac How to squeeze maximum performance from your Mac… Computing power has increased massively over recent years, and for Mac users the switch to Intel processors brought new heights of speed and performance to even the most entry-level Macs. Thanks to the longevity of the average Mac, there are many thousands of older PowerPC machines still in use, dutifully chugging away day after day. And even for newer Macs, applications like working with images, music and video always run more smoothly with more power under the hood. Upgrading the processor, although technically possible on some newer models and with more difficulty on older Macs, tends to be expensive and complicated. The good news is that other parts of your Mac can be upgraded, and components tend to be cheap and user-accessible. In addition, there are simple steps that you can take in order to optimise your system for better performance. Sometimes this involves a little spring cleaning, other times a combination of hardware and software upgrading. Whichever you choose, it's easier than you think to speed up your Mac. You could even feel like you've got a brand new machine. 1. Clear the clutter OS X requires around 20% of the space on its boot drive, typically called Macintosh HD, to be empty so that it can write virtual memory and other temporary files to the space. If a boot drive is very full, your Mac will slow down badly, even if it is a high spec machine, as the system thrashes the drive, overwriting what little free space is available. A good working practice is to keep very large media files like video, image libraries or iTunes libraries either on a secondary internal drive in the case of a tower, or on a laptop or iMac, on an external FireWire or USB 2.0 hard drive. 2. Use faster drives Portable Macs come with 5,400rpm hard drives and towers with 7,200rpm drives as standard. Faster spin speeds generally mean faster operation since data can be retrieved from the drive in less time. On a tower like a G5 or Mac Pro, replacing the startup drive with a faster model like a 10,000 or even 15,000rpm drive will have a positive effect on overall performance and should make the system snappier. Using faster secondary internal drives is good but more important for heavy applications like working with video. Fitting a 7,200rpm drive to a portable Mac will also yield better overall performance at relatively low cost. 3. Add more ports If you find yourself running out of ports, invest in a USB 2.0 or FireWire hub to expand the number available. Make it a powered one and it will supply current to compatible devices as well. On all but tower Macs and MacBook Pros, there's no getting around the bandwidth problem – even with a hub, you're throttled by the bandwidth available on the internal bus. On a Mac with PCI or PCMCIA capability, you can add a card internally with more ports, which provides a signal path directly to the motherboard and so gets around the bandwidth issue. 4. Upgrade your RAM RAM is one of the most fundamental things affecting the performance of a computer. OS X really needs about 1GB of memory to itself to run smoothly, and the more RAM you have, the better. Use the About This Mac menu to see how much is installed, and the System Profiler to see exactly how many sticks are present. About 2GB is healthy for a normal system, and for heavy work with Photoshop, Final Cut or GarageBand you'll need more than that. Different Mac models have differing RAM capacities, with older Macs able to hold less, especially laptops. 5. Manage startup items Some applications, on being installed, place stub or helper programs in your startup items without making it clear that they are doing so. Sometimes this is desirable, say if you always want iChat to open when you log in. But others, typically scanner- or printer-related applications, aren't always needed and can slow down the login process and hog CPU cycles unnecessarily. Go to System Preferences > Accounts > Login items. Delete any you don't need. This rarely causes problems – if it does, put it back on the list. 6. Run only what you need Running applications uses resources including CPU cycles, RAM and disk activity. If you're not using an application, quit it while you run others. Leaving programs open when they're not needed is a resource hog and, especially on older Macs, will slow you down. Some programs can have problems with "memory leakage", meaning when loaded but idle, over time they will consume more and more RAM, eventually slowing you down. Use Activity Monitor located in the Utilities folder to see what resources each program is using 7. Stay lean and mean Keep a handle on what you install. Installing tons of programs and forgetting about them results not only in clutter and wasted space, but can also slow you down. Many programs place library files and startup items into the system, some of which must be loaded on startup whether you use the program or not. Many come with an uninstaller, or you can use AppZapper to completely remove them. Over time, systems invariably get cluttered so if you are confident in your skills, periodically backing up and reinstalling OS X from scratch will keep it lean and mean. 8. Stay up to date Each new version of OS X is faster than the last, and each point update – say from 10.5.3 to 10.5.4 – tends to improve speed and stability. The same goes for applications, so your software and drivers up to date using Software Update and the websites for non- Apple programs. Many apps have a check for updates option. Look at the minimum specs for your version of OS X. If your Mac is barely qualified to run 10.5, you'll have a smoother experience sticking with 10.4.11. 9. Install more memory Having bought more RAM for your Mac, checking first that it is the correct type for your model, power down and disconnect all cables, especially the mains power. Touch a metal part of the casing to earth yourself. Open the Mac's RAM slot, the location of which will differ depending on the model, and carefully but firmly press the modules into place. On G5s and Intel Macs, RAM sticks must be installed in pairs. Close up, reconnect the power and check System Profiler to see if it's working. If your Mac won't start up, check the modules are properly fitted. 10. Know your limits Computer technology advances quickly, but so do the minimum system requirements of software. A seven year-old G4 is unlikely to be an ideal Mac to edit HD video on, for example. But older Macs are far from worthless and can be used as servers, internet and email machines, or even for hosting wireless shared iTunes libraries. Pick up a cheap older Mac, fill it with RAM and big internal or external drives and a wireless card and administer it using Apple's Remote Desktop. 11. Processor performance On some older G4 and G5 systems, you can set the processor performance to Highest in System Preferences > Energy Saver. Automatic switches between the Highest and Reduced settings to optimise energy use. 12. Stripped down A Mac with fewer or even no peripherals connected over USB or FireWire will run a little quicker than the same Mac with loads of printers and webcams plugged in. 13. Out and about When running a laptop off its battery, switching off AirPort and Bluetooth will save power if you're not using them. 14. Multiple accounts Try having one user account for things like games and internet, and another that's more fine-tuned and tweaked for heavier work. 15. Graphics card On a tower Mac, even though you can't always remove the standard graphics card, you can add a new, faster one in a PCI slot and use that instead. 16. Backup schedule Set your backup schedule so it doesn't start to grind away in the middle of your work. A Mac is designed to stay on, so you can set it for the middle of thie night. 17. Disk doctor Perform a disk repair and use something like OnyX to regularly clear out caches, log files and temporary items to keep the system lean. 18. Static wallpaper Using animated desktop backgrounds look great but they use up a lot of system resources unnecessarily, so avoid it if possible. A simple, static photo of a landscape or your family is just as pleasurable. 19. FireWire is faster Despite theory seeming to suggest otherwise, FireWire is actually faster in practice than USB 2.0 for intensive applications like audio or video capture. Give it a try for yourself. 20. Stay organised Believe it or not, folders with thousands of items in them take a lot longer to work with, as the Mac tries to calculate the sizes of the whole folder. Practise good file management.
Isn't 4 and 9 the same? We have MAC at the house and I still prefer my PC. We had one laptop already die after 4 years, the other two crash on occasion. I have two PCs and I cannot think of the last time they crashed. No bashing MAC or drinking PC Kool Aid, but one really isn't SUPERIOR to the other. I'd get a MAC laptop anyday, sure, but it won't be because I hate my PC...
:thumb:RamSus, Looks like you put in alot of time here to help us. Thank You very much. That was very cool of you...
My pleasure, Buddy. I'm not a pro detailer like you guys. I'm an IT guy, so, this is the least I can do to contribute to the forum & pay back those who help answer my questions about detailing.
Oooh cool tips, I love my Mac...I still have about 3 PC's nothing wrong with the PC but I'm glad I got a Mac.
is it sin to use windows on mac lol. i promise i will use mac side eventualy, already bought parallels, just have to install it. windows side is so slow, hope its not same with mac side
