2 3m backing plates for sale!!
Discussion in 'Sale, Trades, or Bargains' started by FMINUS, Dec 27, 2007.
  1. detailersdomain
    yes sir in gray.
  2. matrix_808
    matrix_808 DB Supporter
    whats the difference between the gray and yellow BP besides the obvious color?
  3. MrPolished&Waxed
    bump for question
  4. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    The gray pad is softer.
  5. detailersdomain
    yes the gray is softer.
  6. FMINUS
    FMINUS DB Pro Supporter
    Yellow is for polishing/compounding
    Grey is for finishing
  7. DieselMDX
    DieselMDX Obsessive Detailer
    so then the yellow is the better pad for all applications?
  8. holden_caulfield04
    holden_caulfield04 Virgin Detailer
  9. Asphalt Rocket
    It is like a dampner, its helps with pad hop.
  10. klumzypinoy
    klumzypinoy Nuba Guru
    HAha that's true
  11. holden_caulfield04
  12. BretFraz
    BretFraz Virgin Detailer
    From what I've seen on videos, these 3M plates deflect a great deal while still holding the pad in place. It seems to make polishing in difficult areas and on compound curves easier and safer. Since the plate deflects, you don't have a pad digging into the paint possibly creating a serious problem.
    Also they seem to absorb oscillations better than more rigid plates. All in all, I'd love to use them but not at this lofty price.
    Shipping from the UK isn't bad for a single piece. Its the duty fees and the exchange rate in addition to the shipping. For comparison, I shipped a pair of headphones to Italy a couple weeks ago and it cost me about $20.00 via Priority Mail. Got there in 9 days. I'd imagine shipping from the UK to be similar.
  13. detailersdomain
    once you switch over to this setup you will not go back.
    its smoother and much more forgiving. It makes correction a breeze.
    Is it worth it how much do you detail? If you use a rotary alot I think its a small price. If you pick up a machine once in a while not really.
  14. Asphalt Rocket
    Holden, The backing plate does help, would I buy it again, yes, also Megs makes one , W66. It is not as nice but works, to me it doesn't dampen as well as the 3M.
  15. Nica
    Well like the other guys have said the 3M backing plate helps give a more even pressure on the foam pad and on the polish here are some pictures to better ilustrate what I mean:
    The serious of pictures were taken as I worked the polish in from the very first picture I spread the polish around and then just kept working the polish, you can see how the backing plate helps to spread nise and even pressure on the surface of the paint. Yes the other pads will do the same thing but like it was mentioned before these 3M backing plates will give you that extra support when going around edges or delicate areas. Oh and if your wondering what pad that is, it's the Menzerna Polishing pad quite the pads, quite the pads :thumb:
    One thing to note is how close I bring the pads to the edge and if you look the pressure is even...well when you try it out you'll understand but then again that means spending that extra cash. Is it worth it I personaly think it is but that's just me.
    Well hope these pictures help.
  16. FMINUS
    I feel that the pads cut down on vibration and reduces hop.
    Also it grips the pad like no other BP!
  17. Pats300zx
    I can't wait to get mine :)
  18. jake_b
    jake_b Obsessive Detailer
    well worth the price.
  19. matrix_808
    im still waiting for it too :D
  20. holden_caulfield04
