Zep citrus degreaser
Discussion in 'Car Detailing Product Discussion' started by Frankastic, Jul 4, 2010.
  1. Frankastic
    I use as recommended here 1 oz in my foam gun. I used on my car's paint & my friends vw passat's paint. Using cr-spotless and in shades. It stain all the chrome window trims!!!! Never again on paint. Tires n carpets.... That's it.
  2. :yikes:
  3. Emile
    Emile Welcome to Detailing
    I've said it so many times on this forum that Zep Citrus shouldn't be used on automotive paint. I don't even use it on wheels. It's a great product, but for wheel wells only, and interior duty at the right dilution.
  4. supercharged
    I never used it on the paint...better be safe then sorry...P21S TAW works well...
  5. Frankastic
    Took me 2hrs to repair it with optimum metal polish. Never again on paint. Only p21s aw n power clean for me. But p21 aw is expensive.....maybe 1z blitz or w99?
  6. Emile
    1Z Blitz is great on paint.
    You have to dilute it 6:1 or weaker and it's safe for all exterior surfaces. Phil @ DD knows that 1Z Blitz is my new best friend.
  7. Misha
    Misha Nuba Guru
    used it on my car wtih 10:1 and no issues, but dont have chrom except for H emblem on front. tried P100 TCC but its not the same as P21 TAW like ppl said, maybe it works the same but doesnt look the same, TAW is orange and TCC is yellow. i still use zep on wheel wells and my car with no issues
  8. GDAL
    GDAL Guest
    Sorry to hear that ... I have never had issues with chrome trim and Zep Citrus.
  9. Reflect
    I'm definitely liking this stuff.
  10. Frankastic
    How do you use it? Same method like mine?
  11. lasthope05
    lasthope05 Jedi Nuba
    I've never had any problems with zep citrus. Did some of it dry on there because that is where the main problem is with all chemicals. If its kept wet and not allowed to dry should be perfectly fine. I used it at 10:1, much stronger than your mix, on paint and chrome bumpers and have never seen any damage. :shead:
    Guess I'm just lucky.
  12. Frankastic
    I let it dwell for 1 min in the shade n rinse before I start washing with my shampoo.
  13. Are you for certain the chrome wasn't already jacked up before you started to foam. Kinda hard to tell when its dirty :shead:
  14. 02blackout
    02blackout DB Forum Supporter
    I guess that happened with me too, except I used normal water from the tap and I think the stains were from CG Citrus Wash?
    Before:
    After:
    I just used P21S Restoring Cream on an MF applicator then wiped off with an MF. It works wonders!
  15. Reflect
    Not on paint. I've used it on wheels at 3:1 to no ill effect but I use it for tires and wheel wells.
  16. Frankastic
    I will ask my friend to take picture of it
  17. Dial Up
    Dial Up Birth of a Detailer
    sorry to hear bout that......
    i've used it on my personal/family & company vehicle with no problems
    to remove multiple layers of 845.
    1. pre-soak via spray bottle (approx 10:1)
    2.added less than 1oz to foam gun w/ CG CW (orange)
    3. added 1oz to wash bucket w/CG CW (orange)
  18. Frankastic
    DB no need to be sorry. AG cwc, raceglaze brushes & xl brush, brown royal, n many other great products came out from this forum. I like to try things out myself, but zep citrus won't touch any paint anymore.
  19. 604_Snooze
    604_Snooze Obsessive Detailer
    yup...ijust like blackout's picture, it stained my friend's c300 chrome trims, other than P21s restoring cream, what else will work?
  20. vtec92civic
    vtec92civic Nuba Guru
    wow. never tried zep but this makes me wonder if i should try it or.not
