I personally believe that wool and certain products can cut out alot stronger marks than that Plus you should never get haze from any product even with edge black wool pads Don't you guys slow down the RPM with a rotary once the product has broken down and burnish the surface with the wool pad to not leave any holograms or swirls I most certainly do, with every wool pad including LC foamed wool Hi Temp Extreme cut for instance has allowed me to remove 700 grit scratches (from sanding) and serious abrasion by idiots G Techniq P1 claims to remove 500 grit marks and I really enjoy using it - no swirls at all
