Wolf's Chemicals polishing pads and backing plates have finally arrived!!
Discussion in 'Car Detailing Product Discussion' started by Wolfs Chemicals, Dec 18, 2011.
  1. Wolfs Chemicals
    Hi all!
    So I've been eagerly awaiting the arrival of our new polishing pads and they're finally here!! Wohoo!!! I've been testing them for quite some time now and they have not failed me yet, so I'm very happy to be adding them to The Pack! I call them the "Alpha" and "Omega" pads because for me these are the beginning and the end of polishing. I do a ton of ceramic paints and there hasn't been one yet that I couldn't finish with these 2 pads. This also goes for softer paints.
    Choosing the right polishing pad can get a bit confusing at times, especially for beginners, because there's so many "light polishing" "medium cut" "heavy cut" etc. pads out there that it's hard to choose the right one. Then the confusion of what polish to use comes into play and it can really throw you for a loop. With these pads, the polish determines the cut, not the pad. One pad for cutting and one pad for finishing, it's that simple. I present to you the "Alpha" and the "Omega"...
    The "Alpha" 150 mm
    This pad looks a little aggressive and it can be if you want it to be. It cuts roughly like a wool pad, but will also leave a finish that a wool pad can't. I can use this pad and "X" polish and leave an almost LSP ready finish, but I can also use it to rip through orange peel if needed. Once the cutting is done, the "Omega" will finish things up >>
    The "Omega" 150 mm
    Depending on how well you've finished with the "Alpha" and the hardness of the paint, the "Omega" with our WP-1N through WP-3N can be used to clear things up. This pad can also be used to do some wicked one-steppers!
    I purposely requested that the edges be left squared, as I feel this gives a much more precise cut as compared to the rounded edge pads. It allows you polish closer to the edges of lets say a piece of trim or badges.
    Here's a 740 Li BMW that I did in Romania back in the Spring. Some parts of the car needed to be wet sanded and the paint on the bonnet was a respray and EXTREMELY hard... hardest paint I've polished to date in fact! I wet sanded it with 3,000 grit and despite the rock hard paint, I was still able to polish out the wet sanding marks with the "Alpha" and WP-3N >>
    After wet sanding
    After polishing with "Alpha" and WP-3N medium polish
    Still some slight hazing there, but that was cleared up with the "Omega" and WP-1N finishing polish.
    Here's a Honda that I did on Friday. Butter soft paint, so instead of a compound to cut the scratches out, I chose WP-3N medium polish and "Alpha".
    Before, some RIDS and typical swirls
    After the "Alpha" and WP-3N
    After that I finished with "Omega" and WP-1N.
    Our new backing plate 125 mm M14
    The pads will be going for around 8 EUR each and our distributors will hopefully be stocking them soon! Backing plate prices to be announced soon! Feel free to ask if you have questions!
    - Jesse O'Connor
  2. dsms
    dsms DB Forum Supporter
    This is exciting stuff Jesse, Wolfs is making a lot of headway and this is going to put it over the top!
  3. rwisejr
    rwisejr DB Forum Supporter
    Looks good Jesse very interesting and simple.
  4. Chaseme
    Chaseme DB Forum Supporter
    Everything Wolf's makes looks legit. I have yet to try any but from what people say I'm impressed.
    Needless to say, I have a long list of Wolf's products I need to buy. These will be added to the list.
  5. GDAL
    GDAL Super Moderator
    Looks really promising Jesse. When are you going to send some WP-3N to the States?
    Phil ... are you listening?
  6. detailersdomain
    LOL, I'm always listening.
    Pads will probably be around $14.99 - $16.99 each pad due to all the frieght/taxes.
    As well WP-3N I thought we had some let me check.
  7. GDAL
    Thanks Phil ... let me know if you have a bottle around. I can wait until Spring if you don't.
  8. 604_Snooze
    604_Snooze Obsessive Detailer
    so I guess this is only for rotary right?
  9. Kaban
    Kaban Welcome to Detailing
    Very cool!
  10. kaisernaut
    kaisernaut DB Forum Supporter
  11. ChrisJobe
    ChrisJobe Two Bucket System Washer
    Very nice...
  12. detailersdomain
  13. Wolfs Chemicals
    Thanks for the comments guys :)! We've got some other cool stuff coming next year so I'll be sure to keep you all posted!
  14. Dust2Glory
    Dust2Glory Nuba Guru
    So when you stocking them Phil?!
  15. rwisejr
    Hmm next year is only days away ?
  16. detailersdomain
    if we enough people that want them I will bring them in. so please email me or start a thread.
  17. DirtyWeRX
    DirtyWeRX DB Forum Supporter
    I'm gonna bump this thread!
    Any word if these are coming in yet Phil?
  18. detailersdomain
    email me if you want these, they will be in the 12.99 - 14.99 price range.
  19. DirtyWeRX
    Sounds good Phil. I will probably be ordering a few goodies from you soon.
    How well would these pads work with other polishes like Menzerna?
  20. 604_Snooze
    is these pads for rotary polisher only? I only have a pc
