Winterizing Hint
Discussion in 'Detailing Bliss Lounge' started by Domman56, Nov 9, 2009.
  1. Domman56
    Domman56 Birth of a Detailer
    I'm sure this isn't a new thing for most of you but it's something i just thought of the other day being creative, I know my windshield wipers on my El Camino aren't great so i was in the process of claying and protecting my car and i thought Heyy this should work on glass just fine too. So i clayed the windshield with mothers clay and quick detailer then wiped it down (Wet and Dry) and then put two coats of Klasse All In One on it It looks great and is muuuuuch easier to clean if i get bugs on it and it makes water bead better, Just a thought for you guys out there
  2. pektel
    pektel DB Forum Supporter
    I ALWAYS clay the glass.
    Then I use DG501, then DG105, then DG Aquawax. Killer combo.
    Yesterday I used Blackfire Wet Diamond on the glass. Looks amazing, and beads the water up nicely.
  3. lw81
    lw81 Any Rag Vehicle Washer
    I used a simple glass cleaner (goes on foamy white) and i can't believe how well water beads off the glass. I like RainX as well.
  4. kustomizingkid
    kustomizingkid Nuba Guru
    845 on my glass... i like to razor blade my glass first to knock down the big chunks :D
  5. billyblooshoes
    i almost always seal glass. only takes about 10 more minutes. or ill apply aquapel.
  6. Domman56
    Yup I know it's somethin most of you do I was just thinkin since it was winter i'd remind everybody
  7. supercharged
    been doing that for years. Clean glass - Clay - Klasse AIO...
  8. cptzippy
    cptzippy Jedi Nuba
    Thanks for the glass and +1 that it works well :)
