Subject: BMW 135i Requirements: Quick Interior, Quick Engine Clean Up, Exterior Winter Prep, customer requested to install black out grills Exterior - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down - Wheel wells were cleaned up - Pre Washed with W99 - Iron Cut - Wash down and rinsed - Door jambs were cleaned up - Clayed - Dried - Tires dressed - Masking - Wolf's Shine and Seal - Wheel wells were cleaned - Rubber and Plastics Treated - Exterior windows and mirrors cleaned and sealed - Exhaust tips cleaned - Windows were clayed, cleaned, and sealed - Engine Cleaned and Dressed - Interior wiped down and vac Links to products used - Adam's All Purpose Cleaner Sonax Full Effect Wheel Cleaner Uber Clay Bar Kit Wolf's Shine and Seal Adam's Super VRT Adam's Glass Cleaner Sonax Glass Cleaner Wolf's Chemicals Glass Guard Wolf's Chemicals Rim Shield 1Z einszett Cockpit Tools used Uber Wool Wash Mitt Uber No Name MF Towels Porter Cable 7424XP Uber Buffing Pads Defelsko Paint Meter Fenix TK35 Brinkmann Kranzle Pressure Washer Cam Spray Foam Canon 2 Grit Guard Buckets with Caddies Uber Firehose Nozzle Metro Air Force Blaster Interior Before Vac After Before shots Prep - Pre Wash, Rinse, Iron Cut, Rinse, Clay, Wheels, Tires Wheels before Sonax Full Effect Wheel Cleaner in action APC on tires Pre Wash Rinse Iron Cut Rinse Dry Clay Before Engine After The Wolf Pack for the final steps Glass cleaned with Sonax Glass then sealed with Wolf's Glass Guard Wolf's Shine and Seal applied Wolf's Rim Shield Time to remove the grills and install the black ones Nice touch matches the color and trim very well Afters
Great work Phil, and a nice tough to upgrade the kidneys. Easy if you've done it before, bit of a pain if you haven't!
