Im lookin at DD's website .. they have so many Menzerna polishes to choose from .. ive heard nothing but good things about Menzerna .. so its time I give them a try . I will be doing my mangers Jet Black BMW e60 ... saw the car the other night .. it was dark out .. but with the street light on it .. i could tell it had MAJOR swirls and RIDS .. cars never been polished in it's life time Ive looked at FMINUS's threads and it seems like he uses P085, SIP and 106FA any recommendations ? TIA
Those 3 should serve you well. Also, what kinda machine will you be using?? Flex orbital, PC, or a Rotary?
i always carry power gloss , intensive and final finish polishes. menzerna are sometimes a little dusty but boy do they work.
Specific Paint types / Polish and Foam Pad Combinations: a) Dark or Soft Paint Finishes - PO 85 RD 3.01 Super Intensive Polish (F) black or dark coloured paint surfaces, and 'soft' paint - 1200 RPM -White primary (softer less dense foam (70 PPI) with a light abrasive cutting action ) LC CCS foam pad followed by a secondary Blue finishing (very soft 100 PPI) LC CCS foam pad - 1100 RPM b) Light / Medium Paint Correction - Power Finish (PO203S) and PO 85 D3.01 polishes (LC CCS Green / LC Blue foam or Micro Mesh TufBuf ® black lamb’s wool pads 1500 - 2000 RPM) should be all you need. c) Paint Renovation - PO S34A Power Gloss (LC Purple wool pad 1500 – 1800 RPM) it has a short work time slow cut but tends to ‘dust’
thanks for all the info i will be using a flex 3401 (DA) dusting is not a problem .. due to the fact i take the extra step and do a quick wash after polishing
