Which Decon Gel do you guys prefer?
Discussion in 'Car Detailing Product Discussion' started by 3PedalMINI, Oct 22, 2012.
  1. 3PedalMINI
    3PedalMINI DB Forum Supporter
    Getting Ready todo fall/winter prep, Which Decon Gel do you guys prefer? i see alot of them out there now, Auto Finesse has one now too. Or are they all pretty much the same?
    TIA!
  2. Tegeler
    Tegeler Two Bucket System Washer
    curious as well. I have some Iron X and man does that stuff have a bad odor to it lol.
  3. Wolfs Chemicals
    I prefer Wolf's :D
  4. Paul S
    Paul S Birth of a Detailer
    Only used Wolfs and Iron-X. Iron-X has my vote at the moment. Looking to see what Optimum releases at SEMA .
  5. artemis53
    artemis53 Jedi Nuba
    its really hard to say which is "better". Most everyone will give a different answer for a different reason.
    Iron-X/Iron Cut both seem similar and seem to be pretty strong deironizers
    Wolfs can sit and dwell basically indefinitely
    I haven't seen anything really on AF Iron Out.
  6. Beachzone
    Beachzone Any Rag Vehicle Washer
    I recently bought my first decon spray and ended up going with TRIX. Anyone have any experience with this? I tried it and didn't see much results... Kinda disappointed over here.
    -Beach
  7. vtec92civic
    vtec92civic Nuba Guru
    Really? I use that stuff from time to time, which reminds me i need to order more thanks LoL. It works excellent for what i have used it for. What is it that you are using it on or trying to do?
    It could be that the vehicle or item in question that you might be spraying it on doesn't have anything that needs to be removed thus making the TRIX not activate and turn color. Just a thought.
  8. john baker
    john baker Birth of a Detailer
    i used it not long ago and i thought the same thing,butt you just need to wait longer val 003.jpg
  9. GDAL
    GDAL Super Moderator
    Trix needs to be shaken after a few sprays. It works well for lower panels, but I wouldn't use it to decon an entire vehicle.
  10. Upper Class Detailing
    Did not like TRIX as well. Shake, a few sprays, share, a few sprays, etc....still prefer Iron-X :)
  11. Bmer89
    Bmer89 DB Forum Supporter
    I use Iron-X, works great. You get over the smell cause it does its job lol
  12. Beachzone
    Well I used it on my GF's 2002 Lexus IS300. Never been clayed and paint felt like sand paper around the entire car with a baggie test. It was not maintained very well in the paint department until I got my hands on it. I started with:
    CG Citrus in the foam cannon, Rinse
    CG Citrus Two-Bucket Wash, Rinse & Dried
    TRIX on Basically everything lol (I was really excited to use a decon product for the first time and was anxious to see a ton of purple)
    I was pretty disappointed
    I followed the application directions spot on and the only place on the entire car was here:
    I had a difficult time trying to fight the product drying on the surface. I applied TRIX in the shade, ZERO Breeze, and in the evening before the sun went down so it was actually quite cool outside. I kept spraying more and more to avoid drying out on the surface.
    I was constantly shaking the bottle while applying.
    I will be using TRIX on another bad vehicle soon and see how it turns out again. Any suggestions on other products? I may just go for Iron-X next.
    Thanks for the responses guys!
    -Beach
  13. Upper Class Detailing
    I have Wolf's Decon Version 1, yes V1 :) ... still prefer Iron-X. Have not tried AF yet.
  14. Paul S
    The way I understand Iron-X is it attacks the iron particles on and in the surface. The paint can feel very ruff without having iron deposits or contaminates The roughness you felt could very well be tree sap an non-metalic matter. Thus not much purple showed up on the surface.
  15. Frankastic
    I tried Iron cut, iron X and wolfs decon, my vote goes to wolfs decon. I like the gel properties of it and the smell is better IMO&E
