Like the title says, I just got a system 2000 pad cleaner and it came with one packet of powder cleaner (snappy). I am not ready to do another order with AG yet. Are there any other cleaners that will work as well? I have read that CG Mf cleaner also works on pads...maybe I'll have to order a gallon of that. The only APC I have right now is Fantastic...I'm not sure about using that??? I also heard another method whereby you clean the pad with soap (Dawn) and then use the system 2000 to rinse it thoroughly. Any thoughts?
Congrats on the purchase there richy, you will enjoy the System 2000 saves time on cleaning pads :thumb: I've only used the snappy product...I'm curious as to what others will recomend.
with my pad washer i spray CG microfiber wash or CG total Interior cleaner right onto the pad....let sit while i continue to detail...and just use clean water in the pad cleaner to rinse them clean...works a lot better and saves a lot more product...
I have been using APC, maybe 1oz of APC or less to each gallon of water in the pad cleaner. I use the auto magic 777 APC, but any should work. I need to disassemble mine and get all of the wool out of the gears.
